should i use obx manifold for a red?
Old Jul 15, 2010 | 05:08 PM
smithrcing17's Avatar
like the title says im wandering if i should use an obx manifold with a red? i got the manifold with the turbo but alot of people are telling me it will crack and im gunna have problems, should i keep oem manifold or run this tubular obx manifold??
Old Jul 15, 2010 | 05:39 PM
RockmanX's Avatar
different manifold for sure tubular style all day. mona lisa fullrace shearers or ets
Old Jul 15, 2010 | 06:08 PM
what about megan? are they any good?
Old Jul 15, 2010 | 06:12 PM
daishi77's Avatar
from what i hear megan Emani is crap they end up cracking.
Old Jul 15, 2010 | 06:24 PM
snailman83's Avatar
just get your stock one ported and coated. good enough for 700+ hp evos good enough for me
Old Jul 15, 2010 | 07:23 PM
is it the actual pipe or the welds that crack? my dad owns a machine shop and if its just the welds i could have them gone over and beefed up so they couldnt crack, but if its the actual pipe idk.
Old Jul 15, 2010 | 07:26 PM
IHEARTevoIX's Avatar
i think most of the time.. the welds crack..
but like most have said.. ur better off using ur stock mani..
Old Jul 15, 2010 | 07:48 PM
well flow wise am i going to be better off with the stock mani or this manifold??
i dont have the time or money to get my stock mani ported and polish so that is not even an option.
its either stock mani or this obx mani and ill get the welds all gone over like crazy for free.
Old Jul 15, 2010 | 07:57 PM
VRSF Tiago's Avatar
Any manifold that costs you less than $500 is most likely going to crack pre-maturely. Any OBX, Megan or other ebay brand mani is going to be made out of very thin metal that will eventually fail under the stress of the turbo and downpipe.
The reason the expensive ones don't tend to fail as often is because they are made of schedule piping which is A LOT thicker than the super thin tubing used in the manifold made overseas. It's not because overseas manufacturers can't produce a good manifold, it's the cost associated with a proper manifold.
Keep in mind, if you get a $150 manifold your probably going to have to replace it at least twice in your cars lifetime and with that low price comes almost no customer service.
Old Jul 15, 2010 | 08:11 PM
tim85851's Avatar
stock ported and coated FTW.
Old Jul 15, 2010 | 08:20 PM
Hendrixmx's Avatar
Megan manifold
ScorpionT's Avatar
So many are proponents of ported stockers, although they are good, they simply wont make the power of a good tubular. Ive seen tubulars make 20-30hp over the stock manifold with a stock turbo.
Old Jul 15, 2010 | 08:27 PM
Hendrixmx's Avatar
Yeah with supporting mods, a tubular manifold isn't worth getting unless you're making big power. There are little gains with a tubular manifold and its not worth the money.
Old Jul 15, 2010 | 08:44 PM
VRSF Tiago's Avatar
Tubular manifolds on the stock turbo are a waste IMO
Sure you'll make 20whp in the higher RPM's but you'll lose at least that in the low end/mid range. For a normal daily driver I'd prefer a ported stocker. On a 500+ build I'd go with a quality tubular all day.
Old Jul 15, 2010 | 08:46 PM
ScorpionT's Avatar
http://www.full-race.com/catalog_ima...vo_PS_Dyno.jpg
+29whp on a stock turbo with 272 cams. Thats impressive no matter how you look at it. The original 345whp is nothing significant, definitely doesnt take much. If the OP is running a Red he will see even better power increases with a good tubular.
For what most will pay for good porting/coating, the tubular manifolds are not a bad buy.
