Hallman MBC Boost Source
Old Jul 15, 2010 | 07:55 PM
tscompusa2's Avatar
Id like to hear from atleast 10+ people where the best place to tap for the boost source is for a boost controller? I currently run the boost source off the turbo outlet pipe (stock black pipe).. Im upgrading to a buschur race lower piping setup which does not have the nipple there anymore. My one friend said to run it into the intake manifold, but wouldnt you want it as close as the turbo possible to reduce the chances of spikes and creep and weird boost holding issues? And wouldnt vacuum screw with the air signal in general? So where do you guys recommend tapping into?
Let me know guys.
Old Jul 15, 2010 | 08:15 PM
JohnBradley's Avatar
Nipple on the j pipe to Compressor source, outlet (drilled fitting) to WG actuator. Done, finito.
Old Jul 15, 2010 | 08:18 PM
tscompusa2's Avatar
Ok I thought so.. Thanks Aaron. I will just tap it then.
Old Jul 17, 2010 | 10:46 AM
jam05pr's Avatar
I T'd into the intake and its showing boost fine. Its kinda hard to get an exact psi reading, most are off +/- 1psi
Old Jul 17, 2010 | 12:25 PM
Boost controller needs to have the minimum of signal interference. In, out, done, no other connections preferred.
TS Goofy
Dec 13, 2013 08:28 PM
blakroyal
Feb 2, 2012 10:44 AM
TK40
Sep 2, 2010 03:12 PM
titaniumkingpin
Sep 10, 2004 05:01 PM
93civEJ1
Oct 24, 2003 03:12 AM
