? for the guys with the DIN panel gauges installed
Old Oct 11, 2003 | 07:08 AM
93civEJ1's Avatar
Post ? for the guys with the DIN panel gauges installed
OOk, my first question is for the guys that have installed the DIN
panel gauges in the EVO....When cutting out the 3 holes, mine are 2" cutouts
...how do you keep the clips on there without cutting into them?? OR
do you even leave them on?? It seems that the 2 outside holes are
going to cut into the clips on the panel??
2nd, where do I T into for my boost gauge?
3rd, where do I tap into the ECU harness for the A/F gauge?? or do you
even use the ECU harness at all, and also what did you guys use for
your light sources??
if you can answer these for me, I will be your best friend!
Old Oct 11, 2003 | 05:32 PM
93civEJ1's Avatar
nevermind and thanks for all the help....punks!!
Old Oct 12, 2003 | 12:44 PM
93civEJ1's Avatar
i got the junk in the car and hooked up WITHOUT you guys help...it looks good, I will post pics up soon if I remember, but a big thanks goes out to Blonde on here...
Old Oct 12, 2003 | 01:31 PM
blonde's Avatar
no need to thank me, just post the pics
Old Oct 23, 2003 | 05:27 PM
bpclements's Avatar
Where did you get the Din panel from or is it the stock one? Thanks.
Old Oct 23, 2003 | 07:45 PM
93civEJ1's Avatar
i actually got it from a pal on here........no it's actually one from Mitsubishi for an eclipse...aka radio delete cover....if you do a search on here, you can find the part number.
Old Oct 24, 2003 | 03:12 AM
bpclements's Avatar
Thanks man.
LeXcite
Jan 17, 2022 08:05 PM
RallyDSM
Mar 19, 2017 07:05 PM
Jameson_IXMR
Oct 9, 2008 09:08 AM
vtluu
15
Feb 7, 2008 09:40 PM
Methodical4u
Sep 29, 2006 10:34 PM
