2.3 build?
Old Jul 17, 2010 | 02:59 PM
33bull's Avatar
2.3 build?
so last week i spun a bearing (#4) i wanting to do a 2.3 stroker build what all should i get whyle im doing this i know the basics like,pistons .20 rods,crankshaft,bearings,arp rod bolts,headstuds,oil pump, water pump,timing belt, so what do you guys think?
Old Jul 17, 2010 | 03:01 PM
Liquid0401's Avatar
meh, to each his own but Ive heard too many issues with 2.3s.
Old Jul 17, 2010 | 03:12 PM
33bull's Avatar
really,so what would you recomend?
Old Jul 17, 2010 | 03:44 PM
Liquid0401's Avatar
Do that same things you said just keep the stock bore. I wouldnt mess with the block too much and your stock crank should be fine for your goals.
Old Jul 17, 2010 | 04:22 PM
33bull's Avatar
well i would but i spun a bearing so the crank is trash i dont really wanna get it turned,also im only gonna go .20 over because the motor had 55,000 miles on it and just wanna clean up the block a little bit.
Old Jul 17, 2010 | 04:23 PM
Roadrunr's Avatar
Save yourself a lot of headaches and let a pro like Buschur build it for you.
Don
https://secure.buschurracing.com/cat...071c0e98a019ab
Old Jul 17, 2010 | 04:41 PM
Liquid0401's Avatar
I didnt mean your specific crank but a oem crank in general.
Old Jul 17, 2010 | 04:51 PM
jason05evoviii's Avatar
Don
+1
Buschur do some good stuff as well.
Old Jul 18, 2010 | 12:55 PM
33bull's Avatar
what about the Balance Shaft delete?or should i just keep the oem one?
Old Jul 19, 2010 | 06:46 PM
33bull's Avatar
any advice?
Old Jul 19, 2010 | 08:57 PM
RockmanX's Avatar
if your building a motor you delete the BS of course. i personally think you should go with a 2.4. cheaper cores get that 2.3 punch with alittle bit faster spool and plenty of cores all over the place.
