e85/93 pump related question
Old Jul 18, 2010 | 02:32 PM
milford's Avatar
i hope this is in the right section.
My questions are these. i am planning on getting an e85 tune in two weeks but i also want to get a 93 pump tune as well i would be saving both of these maps on an Accessport..so here is where i could use some direction. i obviously need 1000cc injectors for the e85 but i am wondering will i have any problems getting tuned on 93 with those injectors being that my car only has cams and basic bolt on mods, stock turbo as well. so yea im asking if i can get a 93 pump tune with my1000cc's for a stock turbo so i can drive around when i don't have e85? i really don't want to have to switch injectors every time i need to switch maps.
thanks in advance everyone
Old Jul 18, 2010 | 02:39 PM
Svendiesel's Avatar
It depends on the injectors ability really, if you get an injector such as FIC, theyll idle great regardless of how much fuel you need. Theyre very stable.
My friend has FIC 2150's in his car right now with a stock motor (hes almost done building a 2.4 and he decided to throw the injectors in and see how they worked), with FP cams on a precision 6262 and the car idles like stock with not a single hiccup on 93. He will be running E85 once the new motor is in.
Old Jul 18, 2010 | 03:03 PM
milford's Avatar
yea i have read good things about those injectors. i know the duty cycle is going to be way low for the 93 tune considering i only have cams and bolt-ons i just hope its alright. i gotta get a hold of the tuner Monday to ask.. i really would like the 93 map to be aggressive so its still fun to drive but yea i'm just trying to find out if ill run into problems having such large injectors running such a low cycle
Old Jul 18, 2010 | 03:14 PM
Svendiesel's Avatar
The above car I mentioned on 93oct is at 3% duty at idle. At 25psi on the 6262 and stock motor hes at only 36% duty cycle
Old Jul 18, 2010 | 03:47 PM
milford's Avatar
true
Old Jul 18, 2010 | 03:49 PM
Werd's Avatar
1000cc will be fine on 93 oct. I have 1200's and have had zero problems with them, car only runs pump gas.
Old Jul 18, 2010 | 03:54 PM
tro0xazn's Avatar
Your fine, you'll be able to run both e85 and 93oct with those injectors.
Old Jul 18, 2010 | 03:55 PM
ta ace's Avatar
you should be fine
Old Jul 18, 2010 | 04:51 PM
evoviii272tbe's Avatar
I am in California, car was tuned by GST. I run RC 1000cc, walbro 255 and have dual maps - 91oct and E85. the RCs work well with both maps. I also have just basics bolt-ons, Cossie M2 cams with a stock Evo VIII turbo. the car is my daily driver, no issues with idle or driving.
Old Jul 18, 2010 | 05:05 PM
milford's Avatar
thanks for all the responses guys..quick question to evoviii.. what are you using to switch between maps?
Old Jul 18, 2010 | 05:17 PM
fromWRXtoEVO's Avatar
^^ After you are done reading my response you should have no further questions:
Hi,my name is Carlos. I am running 1050cc injectors and I have many bolt ons on my 2006 Evo IX SE. I am running two maps, one for E-85 and another for 91 oct. I switch my maps thought a custom built switch that feeds from a single pin on the ECU plus another pin to lit up a LED plus a 3rd wire for the ground.
Basically I never have to plug in any devices thought the OBD II port such Cobb access port or even a lap top, my simple basic set up is as simple as it gets. Let me get this right again, I have a small black plastic box with a simple toggle switch and a LED built in. The ENTIRE wiring system consist of a ground wire, a power wire(from the ECU) to lit up a LED when switching maps and a wire from a specific pin on the ECU(3 wires in total).
Your car should run perfectly fine with the 1000cc I am running the 1050cc.
Carlos
Old Jul 18, 2010 | 05:22 PM
milford's Avatar
thanks carlos. that was a huge help
Old Jul 19, 2010 | 07:40 AM
Milford: I am using Tephra V5 for map switching. GST prgrammed the intercooler spray toggle switch to do that (not sure if the Evo IX has that switch?).
Old Jul 19, 2010 | 09:34 AM
italianevo88's Avatar
I run 1250s on pump gas with no probs
Old Jul 19, 2010 | 04:02 PM
The Evo 9 doesn't have the switch. I believe the early Evo 8 had the switch. It was after all deleted on newer Evos because it was found to not really improve much.
Carlos
