Is spraying meth on the 2 step safe??
Old Jul 18, 2010 | 10:16 PM
1slowassevo's Avatar
My friend was telling me that spraying meth on the 2 step is not safe to do that it could cause the meth to freeze and crack the pistons while on the 2 step is this true??I have the meth spaying at 4 psi and full at 15psi while on the 2 step I build up to 15 psi of boost..thanks
Old Jul 18, 2010 | 11:23 PM
94AWDcoupe's Avatar
I have read posts of people bending rods on two step spraying meth.
intermittant spark is same thing as misfire. unburnt fuel passing through engine is bad thing with wasted spark ignition. no issue with gas. but with meth and e85 there is potential preignition issues that bend rods with ease.
Old Jul 19, 2010 | 02:01 AM
akeric's Avatar
Is it really awesome for your car..........no not really, but as long as your meth is setup right it shouldn't be spraying more than it would otherwise.
You might get some flames out the back and if you 2step for 2 long it might foul the plugs for a bit but I don't think your going to cause any serious damage.
Old Jul 19, 2010 | 02:03 AM
akeric's Avatar
If he is having a PREIGNITION issue than that would occur even with the spark firing.
On a 2 step the actual load on the engine is much less than if it were actually moving the car so your chances for harmful det should me less as well.
That being said, if improperly setup I'm sure you can cause all sorts of fun issues.
