Exedy hyper or twin plate clutch for EVO 8
one of the best DSM shops
Road Race Engineering
has a GREAT ACT set up for fairly cheap too, im not afiliated in anyway, but have had nothing but positive experiences with them for over 7 years (my car club( Alaska Motor Sports ) now almost exclusively uses this company because of how well they've treated us)
I have been watching this thread all day. A friend of mine pointed it out to me. I decided to join, and share some information. First of all, as was pointed out, ACT is a REBUILT stock unit! Nothing more than that piece of **** you have in there now, beefed up a little, and you use your stock flywheel. EXEDY is OEM for most Japanese car manufacturers. Not to mention general motors as well. The EXEDY Hyper unit is ALL any of you guys need! They include the unit, as well as a chromoly flywheel! SWEET!!! I own an EVO8, and I also bought the Hyper unit from www.coximport.com It is SWEET!!! The stock units were ****! They were manufactured by FCC of Japan, to Mitsu standards. There is your problem. The twin disc set up is overkill for daily driving/strip.
Go with the hyper, where ever you get it. You will have all the clutch you need, and some!
I Agree
i just got the exedy hyper single clutch kit installed and i like it a lot so far.. it's a little tough to drive in stop and go traffic, but not too bad..
btw, does anyone know of the break-in period for this kit?
also what's the weight on the flywheel in the kit?
thanks!
thanks!
Originally posted by JDM EVO 181
Exedy's are new, ACT rebuilt stock units....hmmmmmm, now whichwould you have. That's like Autozone vs. Mits. dealer.
ACTman, your exact words are "We start off with new stock units"
Correct me if I am wrong, but you are indeed rebuilding a "stock unit" That means you are starting with that piece of **** we got to begin with, and sugar coating it. Is it not still just a cast iron cover? If you can build a better clutch than one of the largest manufacturers of clutches in the world, then why are you not doing it?
Folks, do your research. Check out previous threads regarding clutches. There is a lot of misinformation going around. People, clutches are not that complicated.
Indeed they do, as well as ACT who starts with the STOCK cast iron unit. The EXEDY units are ductile iron. MUCH safer under high revs!
