1g/2g dsm cop on evo 8
hey guys, i acquired this setup from a friend, its off of a dsm. just seeing if it will work, and what i need to make it work on my evo. what wires need to be moved, etc. please help me out!!
Silver Sponsor
Ok...there is a lot to wire up and it is not easy. Not sure if it will work non-cdi, but it should.
Coils:
#1 and #4. Connect the transistor trigger wire (OC1) to the top pin on coil #4. Bottom pin of connector #4 to the top pin of #1, and bottom pin of coil #1 to 12v power from transistor.
Same for #2, #3, starting with coil 3.
Now look on the transistor:
GND to Ground from a coil connector or both
OC1 to coil #4 top pin
OC2 to coil #3 top pin
IB1 to #1,#4 input
IB2 to #2,#3 input
TAC do not connect
VB switched 12v from a coil connector or both
This is almost all off the top of my head...
Coils:
IB1 to #1,#4 input
IB2 to #2,#3 input
TAC do not connect
Coils:
IB1 to #1,#4 input
IB2 to #2,#3 input
TAC do not connect
Coils:
IB1 to #1,#4 input
IB2 to #2,#3 input
TAC do not connect
it would be a huge down grade from the stock coils unless you have an amplifier or ignition box to drive them.
Dwell times are different, you will need to wire in the ignition from the DSM setup... It would give you worse performance then the stock set up.
Those coils like energy and lots of it. Even an AEM driving them won't work real well and those boxes can adjust for dwell times.
Not my car and I don't care if you do it, I personally have a setup like Matts and I bought some product from him and it is rock solid.
yo hitman, it's for a evo. it's not for a dsm. sorry if you heard me wrong. when i purchased it, the guy said it's a first gen buschur unit. i had contacted them a while back and they do offer a harness for it.
