Trace amounts of yellow - gold specs in oil
Old Jul 28, 2010 | 06:22 PM
COL Knock's Avatar
Hi,
About 4 years ago I noticed small amounts of copper appearing specs in the spent engine oil. They were very small and sparse, but they were there nonetheless and had me worried.
Well, after about 50,000 miles later, with same turbo (stock), boosting the same 29 - 21 psi, I still see these darn trace amounts of copper specs left behind on the bottom surface the used oil has settled in. They're still small enough to pass through bearing clearances, but I see a little bit more than four years ago.
Anyone know for sure of what the source is?
I have a few possible culprits in mind in order of likelyness:
1) Turbo bearing wear
2) Balance shaft bearing wear
3) Something in the oil pump system wearing (other than high pressure bearing surfaces)
4) Main bearing wear
5) Corrosion debris from hot oil attacking plumbing and welds on oil return parts or any other sump surface that yellow - red in appearance
6) Rod bearing wear
7) Head?
8) Foreign contamination, i.e. gasoline (if specs are small enough to pass filer), sloppy maintenance at one time or another.
Anyone have experience with this?
Old Jul 28, 2010 | 07:55 PM
sparky's Avatar
I'll take a shot in the dark and bet on it being bearings. Accordingly, I'll select either 1, 2, or 6 from the above list. Why haven't you sent an oil sample into Blackstone for analysis yet?
Old Jul 28, 2010 | 08:06 PM
94AWDcoupe's Avatar
turbo bearings is pretty much the only thing that is gold in color in all the things you listed.
Old Jul 29, 2010 | 03:41 PM
COL Knock's Avatar
I should but I just changed the oil and discarded the old oil
Turbo is old and been through quite alot.
What would be a good bolt-on upgrade with similar durability as the stock one I put through hell, BBK?
Old Jul 29, 2010 | 03:45 PM
eXtreme-Speed's Avatar
BBk or green
Old Jul 29, 2010 | 05:38 PM
COL Knock's Avatar
Is the green more durable than the red or black? For an upgrade I would like a little more than what the green delivers.
I've heard much good stuff about the BBK's as far as quality, aren't they supposed to come out with something new or is that project dropped?
Old Jul 29, 2010 | 05:55 PM
McLaren F1 2003's Avatar
yes they are coming out with a larger version of the BBK...dubbed BBK-B
take a look in the dyno results section for more info...
Old Jul 29, 2010 | 10:48 PM
sparky's Avatar
I am wondering. What oil do you run?
Old Jul 30, 2010 | 01:07 AM
EvolutinIX's Avatar
+1 and I would go with the BBK B
Old Jul 30, 2010 | 11:52 AM
COL Knock's Avatar
I was using M1 10.30 when I first noticed traces in the oil. Afterwards I switched to Royal Purple 10.40 and have been using that stuff ever since for about 40,000 miles.
Note that the only time I notice the yellow-gold particles is when I let the oil drain for a good bit of time during changes. Then, when I decant the oil into a container some of the particles can be seen stuck to the oil film.
Interesting to note that tearing up an oil filter does not result in any findings, a usless test for this.
I don't have time to wait for the bbk B, have to settle for the full.
9GUY9
327
Dec 17, 2013 09:16 PM
Jacks Transmissions
Jacks Transmissions
Jan 4, 2013 10:52 AM
okevolutionVIII
Nov 7, 2012 04:38 PM
jonvr4
18
Dec 2, 2011 06:15 PM
otter
Jan 5, 2010 11:17 PM
