spark plug help
Old Aug 3, 2010 | 01:21 PM
sktng22's Avatar
spark plug help
ok so i have an evo 8 and i hear u can use bpr8es spark plugs? What do i gap these things at when i get them?
Old Aug 3, 2010 | 01:28 PM
Sinbig's Avatar
https://www.evolutionm.net/forums/ev...ark-plugs.html
You flowing enough boost for those plugs?
Old Aug 3, 2010 | 04:58 PM
sktng22's Avatar
There 1 step colder I figured 1.5 bar with kelford 272 cams should be enough no?
Old Aug 3, 2010 | 07:41 PM
sparky's Avatar
22-23# of boost is about what I am running as well. You'll want to gap your plugs somewhere between .022" to .028". I usually run a .024" gap.
You could go wider than .024" if you do mostly highway driving. Conversely, you may wish to tighten the gap down below .024" if your car sees a lot of stop-and-go traffic with extended engine idling, or if you were ever to switch over to Meth injection and higher boost levels
Old Aug 3, 2010 | 09:02 PM
Sinbig's Avatar
Should be. Call your tuner. The guy I talked to recommended going colder at about 400 whp but I didn't research that further.
Old Aug 3, 2010 | 09:11 PM
bluebanana23's Avatar
.024 works well for me at 23psi on IX turbo (93 oct)
Evoguy!123
Jul 20, 2016 07:26 AM
Bhsj13
Jun 15, 2016 03:15 PM
vietdragontekx
17
Jan 2, 2014 12:51 PM
gvillevo
12
May 25, 2010 09:32 PM
8ASTI
Jun 21, 2005 06:50 PM
