how many quarts of oil?
Old Jun 13, 2013 | 05:24 AM
IRISHEVOX's Avatar
What does the Owners manual say for the EVOX?
Old Jun 13, 2013 | 07:32 AM
Fast_Freddie's Avatar
Veteran: Navy
5 quarts for me
Old Jun 13, 2013 | 07:42 AM
heel2toe's Avatar
I'd try the Evo X section of this forum and you may have better results. I'd guess its around 5 quarts as well. And not to be a dick but you own the car. Open up your glovebox and take a look. If you dont have an owners manual I suggest you purchase one.
Old Jun 13, 2013 | 08:14 AM
barneyb's Avatar
The last time I checked all car engines have a dip stick.
Old Jun 13, 2013 | 08:21 AM
heel2toe's Avatar
^LOL
Although I was checking the oil for my boss's wifes Mercedes and come to find out that it didnt have a dipstick. The oil level is monitored by the computer and tells you when its low and how much to add. I hate that btw
Old Jun 13, 2013 | 08:40 AM
gsrboi80's Avatar
Originally Posted by heel2toe
^LOL
And most if not all have no oil drains bolts either. Fun Fun
Old Jun 13, 2013 | 08:45 AM
heel2toe's Avatar
Yeah you've gotta use a vacuum pump to get it out...good times
Old Jun 13, 2013 | 11:29 AM
TommiM's Avatar
some M112 and M113 MB engines didnt have a dipstick, but there is a "special tool" dipstick that reads in mm to verify the oil level. I like using that vs the instrument cluster when one comes in the shop, its more accurate. They all have oil drain bolts but some shops and some techs prefer to suck it out. Ive never been a fan of doing it that way. I gotta raise the car to inspect it anyhow.
Old Jun 13, 2013 | 05:45 PM
ExViTermini's Avatar
^^ beat me to it! A lot of the newer BMW's were the same way, good bit of newer Porsches as well. The Panamera you have to drive the damn thing 7 miles before it will even check the oil. ****s rediculous what the jackass german's have been doing.
Old Jun 13, 2013 | 06:02 PM
Ricoswave's Avatar
Should be 5 in the car, my oil cooler holds about .5 qt so I have to put in 4.5 every change.
Old May 12, 2014 | 11:41 PM
mrm95's Avatar
I usually put 4.4-4.5 quarts in mine and that puts me right under the full notch but still between the 2 notches so its good to go.
Old May 13, 2014 | 12:01 AM
dsm nexus's Avatar
5.5 for a bone dry motor?
fast03evo
Jun 14, 2015 05:33 PM
Roen
Mitsubishi TC-SST Discussion
Mar 19, 2014 08:29 PM
TurboKaren512
Feb 9, 2007 02:05 PM
chase
Feb 13, 2004 08:08 PM
