fp red 64mm spike.
Old Aug 14, 2010 | 02:21 PM
stryfetew's Avatar
fp red 64mm spike.
Recently after fixing a BOV leak I have seen my car spike to 31+ at 8k rpm with a 64mm red. No matter how the duty cycle is adjusted etc it still spikes. was told it could be the bov spring replaced it.. same thing..
Buschur ported coat exhaust, 64mm red, forge dv006 w/ red spring injen piping grimmspeed bcs omni 4 bar tephra v7
It builds the desired boost up until 8k rpm then it for some reason surges/spikes to that boost level. I'm lost for ideas of what it could be. I'm thinking maybe a faulty map sensor, faulty boost controller.. I dunno.. Any advice?
Old Aug 14, 2010 | 02:26 PM
4doorstreetbike's Avatar
what o2 housing are you using??also what mbc?
Old Aug 14, 2010 | 02:32 PM
RockmanX's Avatar
you sure its not the typical surge associated with the 64mm reds lol hints why they made the 84mm cover for them?
Old Aug 14, 2010 | 02:36 PM
scheides's Avatar
EvoM Moderator
Make sure you have your WGA tables set to max out at like 9000, not 8000. Sometimes they will just go to 100% and cause boost to spike in high revs like that.
Have you logged WGDC to make sure this isn't the culprit?
Old Aug 14, 2010 | 02:38 PM
stryfetew's Avatar
I've done a ton of logging but 4ws is doing my tuning i'm just going by what he is telling me. And if you can point in the direction of the tables i'll be sure to check them out.
I just checked and no I have not logged WGDC.
Old Aug 14, 2010 | 02:44 PM
stryfetew's Avatar
I can provide a log too if you guys think that would help try and solve the issue.
Old Aug 14, 2010 | 03:02 PM
stryfetew's Avatar
it's an ebay housing and the grimmspeed electronic boost controller
Old Aug 15, 2010 | 06:14 AM
cij911's Avatar
It does not sound like surging to me (sounds like ECU boost issue)....A few ways to narrow it down:
(1) Install MBC - this will take no more than 5 minutes and will let you determine if it is the ECU controlled boost or something else....
(2) Log target boost and / or WGDC
(3) Log boost and TPS - I would like to see if the high boost reading is while you are still on 100% TPS or after you have lifted
Old Aug 15, 2010 | 06:19 AM
stryfetew's Avatar
I did log WGDC not the target boost etc.. It went from 40% duty cycle to 60% to 78.34% from 7200 on. I'll do a log with those values and report back.
Old Aug 15, 2010 | 06:24 AM
cij911's Avatar
Is it possible you are seeing a boost spike after you let off the throttle (BOV not opening) ? The reason I am asking this is because you mentioned the issue occurred after you messed with the BOV.
Old Aug 15, 2010 | 06:41 AM
stryfetew's Avatar
It's possible I did hear it open though.. It had a boost leak which after we fixed is when all this started. Had the blue spring installed swapped it out yesterday for a red spring and the same thing.
Old Aug 15, 2010 | 06:55 AM
sparky's Avatar
cij911 is on the right track, I think. As he suggested, you could try installing an MBC to see if that'll allow you to eliminate the spike. Also, you might want to replace your BOV with a factory metal MR DV for comparative purposes just to see if that'll fix the problem.
The stock metal DV per se usually won't create boost control issues. If properly functioning it is fairly neutral. Aftermarket BOV's if properly setup may work extremely well. However, in some cases they may require careful setup and fine tuning to function flawlessly.
If the above two fixes do not pan out then try the following method while leaving the stock DV in place instead of your aftermarket unit: Disconnect your boost control device and don't reconnect the Grimmspeed BCS either.
Next, connect a length of vacuum hose directly from the compressor housing discharge tube's nipple to the nipple on the wastegate actuator nipple. Adjust boost up to your target level manually by rotating the turnbuckle on the end of the threaded, actuator rod.
Old Aug 15, 2010 | 07:00 AM
stryfetew's Avatar
Yeah I agree with what he said.. When I had the aem tru-boost i never had any problems.. Then again the bov was leaking too so I'm not sure how it would of reacted once the leak was fixed. I'm going to see If i can get my hands back on the hallamn i used to have on the car and try it out.
Old Aug 15, 2010 | 07:03 AM
sparky's Avatar
EDIT: Sorry about the double post! See my post #12 above.
Old Aug 15, 2010 | 07:07 AM
cij911's Avatar
OP - You can send me logs, but HONESTLY if you just follow my recommendation (and try the MBC) you'll help narrow down the problem. I also agree with Sparky that changing the BOV to the stock one would help narrow the problem as well.
I am quite confident the issue is NOT the turbo ....
