2.0 Built Engine Project....
Old Aug 15, 2010 | 02:25 PM
Sideck's Avatar
2.0 Built Engine Project, Questions!!!
Hi guys.. i want to build my own engine... then.. i dont have alot experience with evo engines... right now i have 500whps, PTE 6262 Turbo.. stock engine.. i want 650-700....or 40-45 psi
i have access to excellent prices on this brands:
ACL
ARP
Carillo
Cometic
CP Pistons
Crower
Eagle
Manley
Wiseco
GSC
and some others...
i want to know your recommendations for a good combo, pistons, rods, beargins, bolts, etc, etc.... i want keep 2.0 engine... also i need recommendations on clearances, torque specs, oil, etc...
thanks in advance...i really apreciate your help with this project...
Old Aug 15, 2010 | 02:34 PM
OneCrzyEvo21's Avatar
Wiesco Pistons High Compression = Quicker Spool
Manley I Beams - for your power
GSC S3 - Great For Drag
ACL or Clevite Race Bearings
Arp Main Studs
ARP L19s OR MAP H11 / L19 Studs - For your power Level
Manley Crank - 88mm OR Stock
Bore - .020 Over
New Oil Pump
New Water Pump
All new gaskets
Tq specs - Look them up
Clearances - Depends again I like .002 All the way around. Not to tight or too loose
Hope this Helps
Old Aug 15, 2010 | 03:44 PM
Sideck's Avatar
Arp Main Studs
Bore - .020 Over
New Oil Pump
New Water Pump
All new gaskets
Hope this Helps
what compression is your recomendation?? 9.0:1???
Old Aug 15, 2010 | 04:26 PM
omniprobe's Avatar
9:1 is a good choice.
Old Aug 15, 2010 | 04:33 PM
For the 2.0s the most popular choice is 10:1 right now, alot of guys are doing that, you might have to go with JE pistons for that though..still a great piston
Old Aug 15, 2010 | 04:35 PM
Teal2nnr's Avatar
9:1 is almost stock. i believe stock is 8:8 to1. IMO thats a good choice (as far as i know its debatable whether higher comp gets you quicker spool, it will however net you more power at less boost).
Old Aug 15, 2010 | 06:51 PM
Derock2gspyder's Avatar
Arp Main Studs
Bore - .020 Over
New Oil Pump
New Water Pump
All new gaskets
Hope this Helps
+1 if those are your only options for getting good prices! id rather run je pistons and kelford cams but with what you can get good prices on this is a good setup!
Old Aug 16, 2010 | 09:24 AM
Pretty much my set up, +1 on the Kelfords 272/272 FTW
Old Aug 16, 2010 | 09:40 AM
supersal's Avatar
Ordered my Kit from Chris at No Limit Motorsports:
Wiseco 1400HD pistons
Manley Turbo Tuff’s i beam
ACL Race bearings
ARP Head studs
ARP Mains
Cometic Head gasket
Balance Shafts will be removed by my engine builder...
Gona add to that:
Fliudyn Damper
Exedy Twin Rebuild kit
GSC S2 (to replace my HKS 272's, already have cosworth springs and retainers)
PTE6235RSP (to swop out my HTA3076)
Spoolin Up COP
http://evox.forumup.co.za/viewtopic....52&mforum=evox
Old Aug 16, 2010 | 11:07 AM
DFelton's Avatar
That's going to be a great setup when youre done!
Old Aug 16, 2010 | 11:43 AM
ACL Race bearings
ARP Head studs
ARP Mains
Cometic Head gasket
Gona add to that:
Fliudyn Damper
Spoolin Up COP
Nice man! Gonna be a killer set up when its all said n done!
Old Aug 16, 2010 | 12:17 PM
Sideck's Avatar
ACL Race bearings
ARP Head studs
ARP Mains
Cometic Head gasket
Gona add to that:
Fliudyn Damper
Spoolin Up COP
wiseco 1400 are for stroker right??? i want to keep my 2.0.... but im going to take a wiseco route...
Old Aug 16, 2010 | 12:32 PM
Yes i believe the 1400 are for the strokers..Double check though, really try for a high compression though u wont regret it..
Old Aug 16, 2010 | 12:46 PM
supersal's Avatar
I'm also building a 2L, Wiseco 1400HD std style pistons not Stroker Style...
I'm gona be running stock 88mm crank.
Old Aug 16, 2010 | 12:49 PM
Okay so it looks like they make the 1400s for both..Not to sure there, havent done the research since I was building mine..
The stock 88mm Crank is fine..AMS stated that it can handle easily 1000whp
