crank it!
PIC 2 OF CRANK
This is the roughed out crankshaft from the Evo8. There still is a fair amount of work that has to be done to it. So far the modifications have shed 3.5 lbs from the entire crank!
Nice work ! BTW - Ferrarokid built my last motor which has already 3,000 hard - HARD miles on it !!! he did a world class job ! If you want the best possible engine work consider him for the job!
Hurry up and get that engine built and ready to run !
We are also removing some weight of the exeddy flywheel .. the new piston/ rod combo is about 60 grams per cylinder lighter .. so this thing should rev pretty good .. Al, thanks for the positive input ! ! should be running soon .. waiting for the manifolds / turbo to arrive ! ! trying to decide what intercooler im going to run ! ! it all takes time ! !
How are you going to get the balance correct? I understand the knife edge will reduce the drag as the crank swings throught the oil but I thought the reason the weight was there was to balance the reciprocating mass. Are you taking off an equivalent amount on the rods/pistons?
The crank balances out just fine. A four cylinder crank has it's throws 180 apart, so by taking an equal amount off of each counterweight the balance does not get upset. All it needed was some fine tuning on our balancer after the modification to zero the crank out in both kinetic and dynamic planes.
That is a good and honest question, and not to be disprespectful in any respect, but inline engines do not require bobweights to be installed in order to get them to balance out. An example of a crankshaft that would need bobweights installed (Probably what you remember seeing) would be a small or big block crank from a V-8 motor. This crank gets balanced on its own, and the rods and pistons separately.
