Random sudden 3rd gear grind. HELP!!
Old Aug 17, 2010 | 05:02 PM
mitsuevo803's Avatar
I woke up today and 3rd mysteriously started grinding. It was fine up until i woke up and it was grinding. Im running ACT TTP spec 6puck clutch with HD pressure plate. I had adjusted the clutch a while back and then again recently and was having no issues for weeks. Then 3rd gear grind started. Also today i was getting slight lockout at low rpms. When shifter was in neutral sometimes (only today) gear was still engaged. Clutch has 20k miles but does not slip. Any advice please give me input, thanks a bunch. Thinking its air bubbles in clutch, 3rd gear syncros are fried or throw out bearing??
Old Aug 17, 2010 | 08:49 PM
I adjusted the clutch today and it made it a LITTER better. If I granny shift into 3rd it only grinds half the time. Over 4k rpms from 4th to 5th now grinds sometimes after the adjustment. The clutch is not slipping, it still pulls hard in every gear...
Old Aug 18, 2010 | 03:38 AM
huevosrancheros's Avatar
did u try bleeding your clutch line and putting in some new tranny fluid????
Old Aug 18, 2010 | 03:46 PM
still*boostn's Avatar
^+1!
Old Aug 19, 2010 | 03:46 PM
Will be doing this weekend. Thanks guys! I really hope thats the problem.
Old Aug 19, 2010 | 05:24 PM
dxbevo9's Avatar
had the same clutch on my first evo...gave me the same problem..when i took the tranny appart i came to find that the synchros on 3rd and 5th were gone...cheap parts but very costly labor
goodluck
Old Aug 22, 2010 | 02:08 PM
Today when I woke up and drove the car it was fine...odd...I didn't touch the car since it started grinding...
Old Aug 23, 2010 | 07:22 AM
racr00089's Avatar
mine grinds into third also because i havent adjusted the clutch pedal yet. Mine seems to start grinding after 15 or more minute drives. If you have the same problem as me you might not have felt the grind becuase it was a short trip.
Old Aug 24, 2010 | 06:32 PM
I just took a 2500 mile road trip last month and it was fine...not a short trip lol
Old Aug 24, 2010 | 06:57 PM
silver97's Avatar
sounda like a synchro to me
Old Aug 26, 2010 | 02:06 PM
Hope not...but why would it be fine all of a sudden?
Old Aug 27, 2010 | 10:46 AM
ezz-e's Avatar
Had the same problem an came out to be the synchros
Old Aug 27, 2010 | 10:56 AM
project_skyline's Avatar
Put the car in first with the e brake on. Rev it up with the clutch in to 7200rpm or so, if the car moves forward the clutch is still dragging.
FYI TTP spec 6 puck=same as standard ACT 6 puck
Old Aug 27, 2010 | 11:02 AM
RoMeIX's Avatar
Same problem here, ended up getting the 3rd and 5th syncros replaced.
Old Aug 28, 2010 | 05:27 PM
It stopped grinding. I hope it doesnt start again...but i fear it will again. If its syncros, shepherd transmissions is going to get a call from me
