lose power with no exhaust?
Old Aug 23, 2010 | 10:42 AM
Parikh1234's Avatar
On the IX build, I want to just do a straight dump out the side to save weight. Do you guys see any issue with this? I was just going to have the fabricator make a nice straight pipe that vents out below the passenger door.
What do you guys think? We were unclear as if it would not have enough backpressure.
Old Aug 23, 2010 | 10:45 AM
mtxfrk2k1's Avatar
i have yet to do this on my evo but i can tell you from subaru experience.
i had better bottom end and less top end when i was open downpipe.
Old Aug 23, 2010 | 10:53 AM
Drew_FL's Avatar
Dump it out the hood. Smokestack style.
Old Aug 23, 2010 | 12:11 PM
XxApollynxX's Avatar
From all my studies, and seeing dynographs and cars at track etc. Open cut-out or exhaust will yield higher RPM power, and be very loud haha. I dont see why you would lose or have any problem running open exhaust turbos love to breathe!
Old Aug 23, 2010 | 01:13 PM
RunThat's Avatar
Exhaust back-pressure + turbo = BAD. The easier and faster exhaust can exit the motor/turbo, the better. Period. I run an open dump and open down-pipe. Loud? Sure. More power? YES.
Old Aug 23, 2010 | 01:53 PM
3gEclipseTurbo's Avatar
On a stock evo8 turbo I lost 40+wtq going from full 3"tbe to 3" open dp. Gained about 10whp, not worth it if you ask me unless your pushing 900+whp.
Old Aug 23, 2010 | 02:17 PM
95630706's Avatar
...And there you have it from EvoM, 5 replies, 5 different answers. LOL.
I'm just glad open pipe guy doesn't live near me .
Old Aug 23, 2010 | 02:39 PM
2003lancerevo8's Avatar
well I see your thought however what type of setup are you looking to run anyways? If there are people running low 9 seconds with a full 3 " exhaust, would your car be running any faster than that?
I think there is better things to address if your making a drag car than an open exhaust....
chassis / tire setup would be more of a priority than anything
Old Aug 23, 2010 | 03:11 PM
COL Knock's Avatar
On a turbo car the less backpressure behind turbine or WG the better, no matter what.
Ideal would have an open hotside with 4-5" exducer transition and open WG, but that would melt stuff under the hood.
Freeing up backpressure would cause WG to open earlier due to greater pressure difference so a tighter preload will be needed to hold more boost.
Old Aug 23, 2010 | 03:15 PM
evonam07's Avatar
ull gain some powah!!! my brother has a QTP on his 9 and made around 40hp more..thats becuz hes runing stock exh hehe
Old Aug 23, 2010 | 03:22 PM
Just leave
Old Aug 23, 2010 | 03:23 PM
This thread is gonna get out of hand very quick, just because of those statements
Old Aug 23, 2010 | 04:38 PM
mollett89's Avatar
jesus i love all the opinions who is wrong?
Old Aug 23, 2010 | 04:47 PM
https://www.evolutionm.net/forums/ev...-vs-hp-tq.htmlHave fun reading
Old Aug 23, 2010 | 04:53 PM
erald01's Avatar
you will be fine, YOU DO NOT NEED BACKPRESSURE IN A TURBO CAR PERIOD...so a side exhaust will be fine BUT annoying if you dd the car.
