Tracking gear shifts
Old Aug 27, 2010 | 05:18 AM
Mosaic's Avatar
Hello all:
I am interested in tracking gear shifts to enhance boost/traction control.
Are their gear switch solutions available?
Thanks
Hmm, well after 50 views I guess this is an unknown area.
I have a limited approach that I call the upshift boost/traction sequence. It's an add on feature to a boost controller.
Using the tps or the map manifold delta Pressure I can achieve boost control based upon actual SHIFTS.
By tracking the sudden tps change or manifold boost/vac transitions.
Limitation is I can't tell the direction of the shifts so it's only good from the point of view of a pull from stop. Not for the up/downs of traffic or hills.
Works like this: (activated from a button on the dash etc.)
No shift = 1st gear = 1st gear boost limit.
1st shift = 2nd gear= 2nd gear boost limit....and so on.
4 th shift = switch to standard boost control based on tps/rpm maps.
Any thoughts on the usefulness of having this capability? Would U want to have it?
Old Aug 27, 2010 | 06:03 PM
Mosaic's Avatar
Alternatively a math function of RPM vs VehicleSpeedSensor could do the trick quite well.
Does anyone have an ECU pinout showing the location of the VSS for Evo8 thru 10?
Old Aug 28, 2010 | 01:09 PM
impact blue's Avatar
I would like to know more about this too.
