Is Samco IC hose kit worth the money?
Old Nov 24, 2003 | 01:49 AM
JT-KGY's Avatar
I mean... are silicon hoses cost that much??... 7 pieces of silicon
hose couplers that cost more than $250...
Are they worth it??
I'm seeing less boost winter than back when I just got the car in
summer... so I might remove the front bumper to check on all
the IC connectors.... and while I'm at it I might as well upgrade
all the connectors with silicon couplers...
(Vendors: whats the best price for your samco kit? )
Old Nov 24, 2003 | 04:15 AM
eclipsegs2k1's Avatar
yeah, i am about to buy the samco kit i think, and i was wondering what other peoples experience with it on here. i did a search and found a little bit but not very much recent info on it.
Old Nov 24, 2003 | 06:25 AM
Zeus's Avatar
...a while back, someone posted it was worth 4-6whp and better throttle response... might have been Silver Surfer, but I can't remember.
Old Nov 24, 2003 | 06:30 AM
Eric Lyublinsky's Avatar
I would not think it would make anymore power. And 4 to 6 hp between dyno runs even on the same stock car are not un heard of.
Eric
Old Nov 24, 2003 | 06:39 AM
EVO-Bill's Avatar
From what I hear, the bottom IC piping is the really restrictive one, but the top is fine.
Old Nov 24, 2003 | 09:24 AM
Zeus's Avatar
Eric
I wasn't arguing the point... merely stating what I remember was posted... If you want to go there, you could state that a dyno operator could make a dyno vary 10-20hp (conservative) based on inputs...
Old Nov 24, 2003 | 09:32 AM
I wasn't arguing the point. Just a statement. I have hoses my self and did not feel a thing. IMHO.
Eric
Old Nov 24, 2003 | 09:45 AM
Zeus's Avatar
Eric
Finally, someone who has them speaks up and says so.
Old Nov 24, 2003 | 11:57 AM
JT-KGY's Avatar
I just remember seeing a video of the engine bay when the
owner was revving his engine... I was surprised how much the
rubber coupling (next to the battery) flexed and ballooned every
time the guy gets on the gas...
Old Nov 24, 2003 | 02:38 PM
Zeus's Avatar
I had the wife blip the throttle while I watched the hoses expand about a 1/2"... I can't imagine how much they expand under 19+psi.
Old Nov 24, 2003 | 04:41 PM
SILVER SURFER's Avatar
That wasn't me, I am still running the stock hoses/pipes. Looking at the stock hoses, I don't see how the samco hoses would flow any better, infact the external sheath on the stock rubber hoses should make them ballon/flex less than the samco. Unless they are double reinforced thick rigid hoses, and they do not appear to be. The only advantage I could think of to the silicon hoses is that they hold up better over time to heat, pressure, chemicals, and of course some think they look nice.
I still cannot find anyone who has tested the upgraded intercooler hose/pipe kits and found any substantial gains from just that part? The stock hose/pipe setup is really dam good for stock. I suspect for a mildly modified car, your just wasting your money. Of course someone could always prove me wrong.
I think one of the venders on here tested a pipe kit and quietly admited that they did not see any significant gains, that was quite a while ago so... I am sure with enough upgrades, turbo, etc, you might start to see some benifit, but I would do the intercooler before the hose/pipe kit. Also those rubber hoses seem to have a larger diameter and more gentle curves than all of the hard pipe kits I have seen.
If your going to spend that kind of money on a few bent pipes and hose connectors, at least go for a 3" setup and really do it right, ya know?
Old Nov 24, 2003 | 04:50 PM
ex-honda's Avatar
Just my .02 . When you do change those hoses,make sure that the clamps are damn, damn tight. I removed my upper hose/pipe to install an RMR aluminum intake. When I put them back, I thought they were tight enough.....WRONG. When I was passing up a car the damn hose to the throttle body popped off. So make sure they are really really tight!
Old Nov 24, 2003 | 07:34 PM
Zeus's Avatar
Sorry, I can't remember who it was, or if it was in a thread or PM (I seem to use PM's more than the open threads). I just remember it being someone's opinion I would trust more than average, and it being a sleight increase.
If the re-enforced silicon hoses balloon less than the stockers, I can easily see how they might improve flow... I still can't believe how bad the stockers swell. Five hoses expanding a significant amount can't be good. However, I've seen no proof that the aftermarket hoses do indeed swell less.
Old Nov 24, 2003 | 07:49 PM
w2pac12345's Avatar
get the Buschur tubing.
ProStreetOnline
May 11, 2015 03:50 PM
mjc1055
Jul 14, 2013 05:42 PM
nightwalker
Jun 5, 2010 11:18 AM
Evokid03
Apr 24, 2010 01:12 AM
gldenchld
43
Apr 16, 2004 03:55 PM
