How to Replace OEM Balance Shaft Front & Rear Bearings?
Old Sep 5, 2010 | 05:45 PM
jameswwt's Avatar
Hi Guys,
can anyone share how to replace OEM Balance Shaft Front & Rear Bearings?
Can it be done at workshop (manually)? or do i need to send the block and bearings to the machine shop to do it?
As 1 of my friend done it b4 in a workshop and the mech screwed the new set of bearings when installation...We don't know why,but its seem very difficult to pushing the bearings into its place without much resistant and this has caused the bearings to damaged.
Please kindly share on how to install it....Thanks
Old Sep 5, 2010 | 06:58 PM
94AWDcoupe's Avatar
I made a tool from old shafts. weld old bearing to shaft. then grind down outside diameter of bearing so it slides past block . To install new bearing I use a shop press. hammering them in will distort shell.
Old Sep 5, 2010 | 08:47 PM
jameswwt's Avatar
Thanks for sharing 94awd, as my whole engine have been dismantle, so do i still need to make the tool as u hv made? what is shop press? is it a tool?
mr evo7
10
Dec 8, 2013 12:54 AM
CrawlinTBSS
Jan 23, 2012 12:57 PM
D-VO
20
Sep 30, 2010 09:24 PM
jameswwt
10
Sep 8, 2010 08:40 PM
thebluesky
11
Aug 27, 2006 09:05 PM
