Which is better? Oem or Eliminator for Balance Shaft???
Old Sep 6, 2010 | 10:55 AM
jameswwt's Avatar
Hi,
i hope anyone can share which is prefered choice :
1) Maintain OEM Balance Shaft and replace the BS Bearings?
2) Go for BS Eliminator Kit?
Please kindly share the different.
Thanks.
Old Sep 6, 2010 | 11:02 AM
casper980's Avatar
AMS Racing Balance Shaft FTW...if your rebuilding the engine, til then stay stock. IMO
Old Sep 6, 2010 | 11:10 AM
jameswwt's Avatar
Hi Casper...Yes,im rebuilding my engine now and i am in a dilema of which way to go....What do u mean of FTW???
Will it be better is i maintain it stock or go for eliminator kit???
Peoples, pls kindly share...
Old Sep 6, 2010 | 11:24 AM
javicracer's Avatar
bs eliminator or ams will be fine!
Old Sep 6, 2010 | 11:42 AM
casper980's Avatar
FTW = For The Win
AMS balance shaft is the way to go. The stubby shafts are not good for the oil pump IMO.
Old Sep 6, 2010 | 05:16 PM
jameswwt's Avatar
Thanks guys...
I wonder is it really that uncouraging to maintain back oem bs setup???
Old Sep 8, 2010 | 09:07 AM
ScorpionT's Avatar
Get the AMS version, or take the stock balance shaft to a machine shop and have them do the same work.
Old Sep 8, 2010 | 07:19 PM
batty200's Avatar
I would NEVER rebuild an engine and leave any form of balance shaft in there. The Stubby shaft is a factory piece and it is fine for the oil pump. The myth that they were bad for the pump was from people using non oem stub shafts without the oil roove in them. I have NEVER seen a documented failure due to a stubby shaft but I have seen MANY balance shafts fail and destroy motors. AMS race shaft is a bad idea. If it was such a good idea why dont engines without balance shafts have a support shaft for their oil pumps? Why does mitsu not use a shaft in the 1.6L 4G61T which rev's higher than the 4G63? Use your heads people. Balance shafts are only used to smooth out the vibrations from the larger 2.0L motor.
Old Sep 8, 2010 | 07:24 PM
stamlon's Avatar
my balance shaft destroyed my motor.. built the SBR 2.4 along with their stubby eliminator works fantastic so far.
Old Sep 8, 2010 | 08:08 PM
RSMike's Avatar
+1, alot of people have confirmed this
Old Sep 8, 2010 | 08:40 PM
javicracer's Avatar
youre correct sr.
SAM_69
20
Oct 25, 2012 11:46 AM
jameswwt
Sep 11, 2010 04:25 PM
Yamahar1
Jul 11, 2009 02:38 PM
dryad001
Aug 15, 2008 05:00 PM
