AMS 4G63 Race Balance Shaft Eliminator Kit
Old Jul 11, 2009 | 09:01 AM
Yamahar1's Avatar
I just bought a used AMS balance shaft Elim kit, and was wondering if you need to do anything to correct the oil pressure?
Old Jul 11, 2009 | 11:01 AM
SeanC's Avatar
You need to block the oil passages on the other side by installing new bearings with the oil hole opening 180 degrees off. The machined AMS balance shaft has an internal oil passage and installs on the other side. Check your clearance and bearing condition too.
Old Jul 11, 2009 | 11:21 AM
Yamahar1's Avatar
I did all that. But now that the holes are blocked off, will that make the oil pressure higher?
Old Jul 11, 2009 | 11:35 AM
EricJ@AMS's Avatar
The pressure at idle and lower RPMs may be fractionally higher, but at high rpm the relief valve will still open and limit the pressure as before.
Old Jul 11, 2009 | 02:38 PM
Yamahar1's Avatar
Ok...Thanks
Migsubishi
Jan 1, 2016 05:37 PM
mines5
45
Dec 7, 2013 01:32 PM
oneofakindracer
22
Aug 24, 2013 08:24 AM
CrawlinTBSS
Jan 23, 2012 12:57 PM
phil_
Lancer-Mirage Compatibility Forum
Oct 22, 2011 10:12 PM
