Typical JE and wiseco 86mm micrometric measure
Old Sep 10, 2010 | 09:03 PM
SeanC's Avatar
Originally Posted by n2oiroc
the clearance is built into the piston. a piston that requires more clearance is smaller and the bore stays the same size. je tech told me .001"-.0015" is about the max you want to hone past stock bore or else the rings will have a hard time sealing good and the end gaps start getting wide.
This is correct. The pistons will already have the clearance "built-in". Your job is to make sure the bore is the correct size, as listed on the piston spec sheet (85mm, 85.50mm, etc.). Typically, forged pistons will provide .0035"-.004" clearance for a 4G63T. JE is right, some of the rings are already at the proper gap, you don't want to bore the block much further because your ring end gap can increase more than you'd prefer.
Old Sep 12, 2010 | 04:34 AM
eTiLiKo's Avatar
Thanks guys, but these assumptions are only theoretical, I have seen forged pistons that have a real measure bigger than what the correct clearance is.
For now the only infos that I have on JE tell that the pistons are usually 0.002" smaller than the nominal bore size.
Can someone confirm or not?
Old Sep 13, 2010 | 08:36 AM
eTiLiKo's Avatar
JE told me that the "in-built clearance" is 0.1mm (0.004"), another guy told me that the in-built clearance for JE tipically is 0.05mm (0.002").....logic tells me to listen at JE, but can I have a confirmation please?
Old Sep 13, 2010 | 08:42 AM
KX250Fmotoracer's Avatar
The spec sheet for my JE's is 4 thou. The pistons are .5mm over and you DO have to file fit rings!
All my pistons measured out to 3.361", I bored/honed to 3.365"
Why can't you convert your mm dimensions to in? Theres 25.4mm to an inch fwiw
Good luck w/ ur build
Old Sep 13, 2010 | 09:13 AM
eTiLiKo's Avatar
Thanks mate, so your pistons .5mm oversize (85.5mm - 3.366") measured at 3.361" !!! An in built clearance of 0.127mm - 0.005" if you bore-hone to nominal size!!!
Old Sep 13, 2010 | 09:18 AM
Yup. You're not supposed to bore to the nominal bore size, you need to measure your pistons and calculate accordingly!
The JE spec sheet said to set piston to wall clearance to .004". If I had blindly bored to 85.5mm that clearance would have been larger by 1 thou.
Old Sep 16, 2010 | 10:16 AM
Euro_Export's Avatar
wiseco pistons
Hey just wanted you to know Euro export is offering free shipping on wiseco pistons. euroexportinc.com
Mortose
May 31, 2016 08:20 AM
bsh
10
Apr 13, 2014 06:13 PM
evolve_VIII
Jun 28, 2013 04:51 AM
Toxin
14
Mar 17, 2012 11:44 AM
EvoIIIAj
Feb 4, 2011 07:11 PM
