Typical JE and wiseco 86mm micrometric measure
Subscribe
Sep 7, 2010 | 03:14 PM
I need this infos from some of the engine builders of the forum.
On a JE 86mm pistons set, how much is the typical and common piston measure?
Same question on Wiseco.
I hope that my question is clear, I'm referring to this kind of measurement
Thanks
Reply 0
Sep 7, 2010 | 08:38 PM
my 85.5mm CP's were 85.42 (x3) and 85.43
Reply 0
Sep 8, 2010 | 02:17 AM
Thanks mate
Anyone for the JE?
Reply 0
Sep 9, 2010 | 01:26 AM
Nobody use JE pistons?
Reply 0
Sep 9, 2010 | 02:25 AM
why are you after this information? are you thinking your pistons are different?
Reply 0
Sep 9, 2010 | 12:43 PM
Because tomorrow I'll go to see and measure an 86mm 4G63 that has some light scuffing sign on cylinder walls. I have to arrange for a piston set that can have a good fit into the cylinders (that will be honed with a professional portable honing tool).
Reply 0
Sep 9, 2010 | 12:56 PM
oh ok, so just go by the JE spec sheet then?
Reply 0
Sep 9, 2010 | 01:06 PM
And where I can find it?
Reply 0
Sep 9, 2010 | 01:16 PM
email JE and ask for it? check their website?
Reply 0
Sep 9, 2010 | 03:59 PM
I would ask that everyone use inches for their measurements. As thats what most go by when checking for PTW clearnce. As most piston manufactures list suggested PTW clearnces in inches, example .005in. So you should be measuring the piston in inches anyways.
Reply 0
Sep 9, 2010 | 04:53 PM
Quote: I would ask that everyone use inches for their measurements. As thats what most go by when checking for PTW clearnce. As most piston manufactures list suggested PTW clearnces in inches, example .005in. So you should be measuring the piston in inches anyways.
its simple math to change it to mm.
Reply 0
Sep 9, 2010 | 05:00 PM
ya but I dont feel like doing extra math...
Reply 0
Sep 9, 2010 | 05:05 PM
Quote: ya but I dont feel like doing extra math...
thank goodness it's not you doing the measurements then...
Reply 0
Sep 10, 2010 | 06:22 AM
There's nothing on the website, and I prefer first hand measurement from experienced engine builders. That's not one of the Fatima's secrets....
I dont want to know the top secret P2W clearance that someone use, I don't need it, I need only the piston measure.
Reply 0
Sep 10, 2010 | 07:22 AM
the clearance is built into the piston. a piston that requires more clearance is smaller and the bore stays the same size. je tech told me .001"-.0015" is about the max you want to hone past stock bore or else the rings will have a hard time sealing good and the end gaps start getting wide.
Reply 0
