About boost psi with MBC closed!!
Old Sep 9, 2010 | 08:41 AM
LanEvo IV's Avatar
Question About boost psi with MBC closed!!
Hellos guys, I have a Evo 4 (JDM) with Evo 8 Ecu. The car has Evo 9 turbo, external wastegate (Tiall 38mm), turbo header and turbosmart MBC. The Ecu has reflash too....
I have problem with boost leak, and two days ago, I changed the BOV graddy RS to original BOV (plastic BOV Evo 4). the car run perfectly, but I put the boost controller closed, but the turbo charged 15 psi, sometimes until 19 psi with the turbo smart MBC closed....
Yesterday I changed the BOV plastic with the new Greddy RS recirc and made the same... This is normal (15 psi) with the MBC closed???
Old Sep 9, 2010 | 10:20 AM
charlie.tunah's Avatar
no clue what your question is....
But if the MBC is "closed" (no boost signal getting to wastegate), the turbo will just build boost uncontrollably. If the MBC is "open" (ALL of the boost signal going to the wastegate), it will run on wastegate spring pressure. My setup will build about 13 psi on wastegate pressure.
Old Sep 9, 2010 | 10:51 AM
LanEvo IV's Avatar
In the worst case my car should give 9 psi of boost of external wastegate, or not???
Old May 4, 2013 | 12:02 AM
Werdna06's Avatar
im more newb than you. what's mbc?
Old May 4, 2013 | 12:26 AM
ragyan03's Avatar
Correct me if I'm wrong..usually if you turn the mbc all the way to the left meaning closed you should be boosting what whatever your Wastegate is..something like that
Mbc is manual boost control
Old May 4, 2013 | 11:21 AM
Werdna06's Avatar
thanks, that definitely cleared up some confusion.
galantman03
43
Feb 5, 2017 09:54 PM
llabmik2
12
Feb 2, 2017 07:25 AM
meat_EVO
May 26, 2008 03:52 PM
evouser12
18
Feb 26, 2006 10:38 AM
lvNVevo
Oct 5, 2005 03:39 PM
