weird boost problem.
Old Mar 9, 2007 | 09:13 AM
llabmik2's Avatar
Question weird boost problem.
I can not boost over 20lbs, i have tryed going from the turbo nipple to the wastegate. Then i tried to splice the bov to wastegate. Now all i get is a higher spike. Still can not go past 20lbs. I have a Hallman MBC and forge WGA, I just changed it from a slowboy MBC and stock WGA and that didnt fix anything. I have tried diffrent preloads on the WGA that doesnt do anything. I tested for boost leaks, didnt have any. In 5th gear it will hold 25psi with the pedal to the floor but that is the only time it goes over 20. I have the MBC hooked up right. so its not that. With the stock WGA i would hold like 10lbs just running WGA pressure. Now with the forge i run 15. On just WGA pressure. Im lost i have no idea what it can be. I have HPF full hard pipe and forge BOV receric. With no leaks. Could i have done something in ECU flash that will keep me from boosting without running the stock BCS?
Old Mar 9, 2007 | 09:18 AM
Warrtalon's Avatar
The ECU has no effect on boost when an MBC is installed, because that takes the BCS out of the loop. Have you tried putting in the stiffer spring on the MBC?
Old Mar 9, 2007 | 09:23 AM
Peteypab2133's Avatar
not sure that is needed, i have boosted 30PSI on race gas on the stock spring with the Slow Boy MBC...
llabmik2's Avatar
Thats what i thought too, i just wanted to make sure. No i didnt get another spring with either of my MBC's. i also figured that if i was doing 10 on stock WGA and now im doing 15 on the forge unit. That i should atleast get 25 psi with it turned all the way down. Because i gained 5psi with the FWGA
Old Mar 9, 2007 | 09:34 AM
Warrtalon's Avatar
Yes, with the new, stronger WGA, it should adjust boost +10 like it was before. Very strange that it's not.
My Hallman boosted as high as I wanted on the spring it came with, but others have had Hallmans with weaker springs that wouldn't go over 20psi...just like the Forge that has two springs. However, that shouldn't matter now that you have the Forge WGA. That's a difficult issue to resolve.
Old Mar 9, 2007 | 10:45 AM
llabmik2's Avatar
well my o2 housing has like 2 bolts in it, i just found that out, so thats a leak right there but that is after the wastegate should that matter. I need to get some bolts for it and put some locktight on them put them back in. That is the only thing that looks to be wrong
Old Mar 9, 2007 | 11:58 AM
Warrtalon's Avatar
It is only supposed to have 2 bolts on the DP side. Are you saying it only has 2 out of 6 on the turbo side???
Old Mar 9, 2007 | 02:20 PM
llabmik2's Avatar
haha yea i know that only has 2 bolts. Yea all i have on the Hotside side is 2 nuts, no bolts at all. Maybe that could be the problem.
Old Mar 9, 2007 | 02:25 PM
Warrtalon's Avatar
Wow, how did that happen? The 2 nuts are on the studs, but you should have a bunch of bolts, too. You're saying there's just 4 holes with nothing in them? Wow.
Old Mar 9, 2007 | 07:11 PM
llabmik2's Avatar
Yea al i have is the nuts on the studs, im going to go up to denver tomorrow, Going to go to a Mitsi dealer and buy a new gasket for it. Then when i get back on sunday im going to take the hole turbo off the car and see whats going on. Ill be driving my truck kinda weird out about the evo right now...Do you think that could be the problem even though its after the wastegate were the leak is.
Old Mar 12, 2007 | 01:45 PM
llabmik2's Avatar
Well today i decided to take off my hotside, just to find out if i could see anything wrong. Well i didnt find anything. I fixed my leak though put all new bolts and nuts on with a new gasket. Took off my stock 02 housing and put on the ebay housing. Still cant go over 20lbs of boost. no matter what boost controller i use. So now i am really lost. I even tryed flashing back to the stock flash all that did was give me fuel cut again haha. So anybody else have so suggestions.
Old Mar 12, 2007 | 06:50 PM
sparky's Avatar
[quote=llabmik2;4067945]........ I have tried diffrent preloads on the WGA that doesnt do anything.
Can you be a little more specific? What preload settings did you try exactly? What was the highest #?
Old Feb 2, 2017 | 07:25 AM
Tommyfacekicker's Avatar
Back from the dead
I know this is a 10 year old thread but did anyone find out what the problem was? I'm having a similar issue. I can't boost past 21 psi. I did hit 24 psi 1 x but that was only one time.
I did boost leak tests n had a small leak from my throttle body. Checked my plugs n all was good, e85 is good, car is tuned to be seeing 30 psi. I have full bolt ons, upgraded ic, 02 dump, speed density, 25g turbo, walbro 450, fic 1450, and hks exhaust camshaft.
Any feedback would be greatly appreciated, Tia.
recompile
May 4, 2025 01:39 PM
parkourpan
Nov 5, 2021 10:29 AM
robh
16
Mar 12, 2017 12:10 PM
simons3z
13
Feb 3, 2017 03:52 PM
MyronGainz
58
Feb 2, 2017 08:21 AM
