witch spark plugs to run?
Well I have an 05 evo 8 and what's done to the car is.......
255 fuel pump
Full 3in exhaust
A tune from paul on here
Ignition from diamond witch I never heard of
That's about it other than built tranny
255 fuel pump
Full 3in exhaust
If you just have those mods and don't really run a large amount of boost then the standard copper VIII plugs will work just fine. If you are having problems with blow out or want to get a nicer plug that won't need replacing so much then go for the NGK Iridiums.
