misfire/tps
Old Sep 10, 2010 | 10:40 AM
evo4sho's Avatar
misfire/tps
So my 2005 lancer evo mr had a misfire and I took it into the shop and said the spark plugs were melting and it needed a tps (throttle position sensor) I know what caused the plugs to melt and it's being taken care of but before it was running on 3 cylinders (due to the plugs melting) it misfired under wot/near wot and the check engine light would come on/off occasionally. was this due to the tps? and by replacing it do you think my car will go back to it's normal self or could something else be wrong?
Old Sep 10, 2010 | 10:42 AM
TeStUdO's Avatar
If your spark plug melted, it sounds like you have a much bigger problem than a TPS.
Old Sep 10, 2010 | 11:18 AM
evo4sho's Avatar
shop says I shouldn't use cheap e3 plugs, and only one melted. says it could be running lean but I should be using correct plugs. guys at checker said I could get by by running e3s apparently not. I don't know what else it could be, my car never runs hot, all temp gauges never hit close to half what they go to. However when I stop at stoplights and what not I notice that you can see heat waves from the motor. seems hotter than the gauges say.
Old Sep 10, 2010 | 12:07 PM
sho669's Avatar
I worked for a big parts house for a little while...their knowlage about recomending parts mostly comes from corporate pushing certain parts with a high profit margin. I love having to tell them I have a 4 barrel carb to get them to look up a headlight in the computer but thought I'd rant, I quit when I couldn't help people rather than just push sale items...
The plug could have melted from just being a cheap piece of crap, swap in a good set and see what happens. Heat waves from the engine are normal, the hood vent is right over the exhaust/turbo remember
johnashton11
11
Sep 13, 2019 01:23 PM
Evo47
Jan 3, 2017 06:43 AM
Evilution23
Jul 18, 2011 10:00 AM
yellowevo82
Aug 30, 2009 02:31 PM
bboy_RES
Jun 7, 2008 02:21 AM
