Valvetrain ticking and phantom knock
Old Sep 11, 2010 | 10:06 PM
amak87's Avatar
I have this same problem I believe.. I'm getting phantom knock at a stand still revving the motor.. ill get up to 36 counts of knock!
In my attempts to stop the ticking, I have installed TTP non ticking lifters, replaced all exhaust gaskets, went back to stock injectors & stock cams (from cosworth272), boost leak tests, compression tests (solid 150psi...), new walbro fp, inspected valve train numerous times, tried all sorts of different weight oils..
Sadly, I have not found the source of the problem, nor the cure.. I have shut off my knock sensor.. I tune my own car via ecuflash & zeitronix wideband... I'm safe cuz I'm always monitoring the motor..
Old Sep 12, 2010 | 06:24 AM
miller121mx's Avatar
Originally Posted by b16a95eg
next time it starts rattling, pinch the big line that goes to back of your valve cover by your intake, see if it stops
I had my doubts, but you were right. Every time it started to rattle, I pinched the line with a needlenose and it stopped. As soon as I'd let go, it rattles again. Does this cause your car get really high knock counts like that? Or does that mean I need to replace mine? I really hope this is what's causing the knock problem, and not something else.
Old Sep 12, 2010 | 06:36 AM
b16a95eg's Avatar
I havent gotten to replacing mine yet either so I couldnt tell you if it'd cure the knock, although, it'd make sense that it would if its knocking audibly enough for the knock sensor to pick up
I get random knock like you were discribing too, so it very well could be it.
Old Sep 12, 2010 | 02:34 PM
I replaced the PCV valve, and the rattling noise stopped. The knock is still there, however. I need to do some more logging, but quick revving in neutral produces lots of knock (over 25 counts) around 3600-4000rpm. For the sake of having more info I will add this: At this same exact range of rpm, my exhaust sound becomes very raspy. Think stock Civic with an Autozone fart can. I don't know how it could be related, but thought I'd throw that out there.
I'm going to do a couple light throttle pulls and log them. We'll see what happens.
Old Sep 12, 2010 | 03:50 PM
b16a95eg's Avatar
Do you have a clutch or Throw Out Bearing rattle at all? I know I got a couple more Knock Counts when I installed my twin disk, for me, free revving in neutral I only get about 9 counts at the same RPM you said, and about 80 load. What do your timing tables look like in that area?
Old Sep 12, 2010 | 05:16 PM
In that rpm range and 80 load, my high octane timing table is 24*. I just hit 19 counts of knock in about the same spot. I did just install a CM stage 3 clutch. Just the single kevlar disk. No audible rattle from it that I can tell.
I just did a light throttle pull in 3rd gear, about 50-60%. Only 1 to 2 counts of knock from 2700 rpm to 3600 rpm, nowhere else in the rpm. Doing pulls on the street I don't hit those high knock counts like in neutral. I'm thinking phantom knock would produce a much higher knock count than that. I'll try to talk to Chad tomorrow and see if he still thinks it's phantom knock or not.
Old Sep 13, 2010 | 05:17 PM
Can I test my knock sensor by measuring the resistance? If so, can someone tell me what the resistance should be? I can't find it for the life of me.
Old Sep 13, 2010 | 05:43 PM
RSMike's Avatar
you can measure the knock sensor with AC voltage on a multimeter. tap it with your fingernail or a screw driver and the voltage will go up. obviously it's not a very scientific method, but can give you a rough indication.
i did this with a 4g64 and 4g63 knock sensor, and the 4g63 knock sensor produced much less voltage with the same force being applied
Old Sep 13, 2010 | 06:17 PM
I can give that a try, thanks.
I'm almost positive it's not real knock now. I had a buddy watch evoscan as I drove around. Doing full throttle pulls I rarely get any knock now, whereas the other day I was getting inconsistent knock counts. Occasionally I hit 36 out of nowhere. I thought maybe the knock sensor was just going crazy or something (wishful thinking). While driving around normal, hitting a little boost before shifts, I am getting kind of consistent knock counts (between 1-4) at the same rpm that the exhaust note gets raspy. At this same time, I can hear vibrations coming from somewhere. I will check my exhaust tomorrow to make sure it's not touching anything. I don't know if that might set off the knock sensor.
I am considering draining my tank until there's only like 5 gallons in it, then putting in a 5 gallon can of 110 octane. If it still knocks on the same conservative tune, then I would imagine it's real.
Even if nobody responds, I will keep updating my findings in case someone in the future has this problem and comes across my thread.
Old Aug 6, 2011 | 12:52 PM
gypsy's Avatar
Any updates? I'm having the same issues and my exhaust also goes raspy
Thanks
Old Aug 7, 2011 | 03:40 PM
I never found any culprits other than the Kelford cams. Later on I found a bunch more people with the same problem with the same cams. I ended up getting a 5 gallon can of race gas, putting it in my empty tank, and then tuning the knock sensor. It was already on a very conservative tune, plus the race gas, so I just turned down the sensor in small increments until the knock disappeared. Then I did more logging with pump gas to make sure it didn't come back. No related problems since.
Old Aug 8, 2011 | 06:50 PM
gypsy's Avatar
Thanks for the update - I appreciate it. Phantom knock is such a headache!
Old Sep 6, 2011 | 10:28 AM
Mauricio Evo IV's Avatar
How do you tuned your knock sensor???
In the load knock tables???
Old Sep 7, 2011 | 08:21 AM
I adjusted my knock multiplier tables for the RPM that I was seeing false knock.
Old Sep 7, 2011 | 08:37 AM
Ok, thanx! but you have Tephra mod????I have stock rom without tephra...
So, I only can change the load knock table.
