vmrevo9's mini build
Old Sep 16, 2010 | 06:59 PM
EVO8STI's Avatar
damn your car is hella clean. it looks brand new!!!
Old Sep 16, 2010 | 08:43 PM
vmrevo9's Avatar
Veteran: Air Force
Thanks! It's not an easy task especially it being my dd and with 2 kids lol
Old Sep 17, 2010 | 09:47 AM
vmrevo9's Avatar
Veteran: Air Force
well today i just got done ordering a tbolt clamp kit and a new reducer for the LICP. i mistakenly ordered the wrong size
next is to order the Misc gaskets and hardware needed.
Old Sep 17, 2010 | 06:03 PM
EvolutinIX's Avatar
Will be following and looking forward to results from the full! Keep us updated, can't wait to see that pretty blue comp wheel and some numbers. Good luck sir!
Old Sep 20, 2010 | 10:38 PM
vmrevo9's Avatar
Veteran: Air Force
i will definitely keep this thread updated. i got a PM from Chad and he received my turbo so that should be here maybe by the end of the week or so. i'm also still waiting on my manifold to come back from PPI. since i wont be upgrading the TB i am going to order the MilSpec shaft seals and i plan on cleaning it up abit.
once everything is in i plan on tuning the injectors and trying to dial it in as best as i can then in november comes the cams and new tune!
Old Sep 22, 2010 | 10:37 AM
vmrevo9's Avatar
Veteran: Air Force
well here is a small update
wrapped and sealed the Downpipe
painted and installed the STM clutch fork stop
and my t-bolt clamp kit came in today!
and i ended up painting my stock UICPs ceramic black
i have enough header wrap that i can either wrap my test pipe, Perrin HFC (which will be installed eventually for DDing) or my ported stock manifold. not sure which one i should do. any advice?
Old Sep 27, 2010 | 11:59 AM
vmrevo9's Avatar
Veteran: Air Force
well no new updates as i am awaiting the turbo and manifold.
any advice if i should wrap the exhaust manifold?
Old Sep 30, 2010 | 06:05 AM
vmrevo9's Avatar
Veteran: Air Force
still waiting on the turbo and manifold. havent heard a thing from PPI and Chad said my turbo should be done ny this week. i was hoping to get everything in by this weekend but i'm not sure if that is going to happen.
i want the car back on the road soon!! my beater truck is getting to me lol
Old Sep 30, 2010 | 07:14 AM
06MREvo's Avatar
Nice little build thread man...car should be fun when its done...Check out my build thread...
I see it says 3.5" intercooler...which intercooler is it? I would suggest maybe swapping the Forge MBC for a Hallman Pro RX...between that and the bbk full your car will hold boost rock solid...I would imagine you should have no problem hitting 400whp+ on AWD's dyno after Dirk tunes it...
Old Sep 30, 2010 | 03:28 PM
vmrevo9's Avatar
Veteran: Air Force
Thanks for the advice. I'll look into the MBC swap. The intercooler is a BYC intercooler. I bought from this forum. I guess it's a clone. I'm really hoping for 400hp+ whp. I guess we'll see. I'll take a look at your thread tonight when I get to my laptop.
Old Oct 2, 2010 | 05:21 PM
vmrevo9's Avatar
Veteran: Air Force
Well today I received the gaskets and hardware along with the milspec seals and TB gasket. Yesterday I had received the injector seal kit I ordered from no limit. So tomorrow I'll be working on my car again! I also received a tracking number for my exhaust manifold and still waiting on my turbo.
Old Oct 3, 2010 | 07:16 PM
vmrevo9's Avatar
Veteran: Air Force
today i got the TB seals replaced with MilSpec seals and the new injector seals installed. now the injectors fit tighter than before which should mean no leaks... hopefully
while i had the TB off i sprayed the intake manifold with some cleaner and it cleaned up nicely although it wont last long due to the EGR crap. but at least it got done.
hopefully early next week i can receive the manifold and give it a couple of coats of heat temp paint and possibly heat wrap it. im also hoping for the arrival of my BBK Full!
i also picked up a compressor this weekend which will come in handy for the boost leak check. and while i was at it i picked up a new grill
Old Oct 4, 2010 | 04:45 PM
vmrevo9's Avatar
Veteran: Air Force
got word that the turbo should have shipped out today so i should have the turbo and manifold by the end of the week hopefully. i'll take pics!!
i also was in need of a shift knob so i ordered one from Adam@MAP thanks again Adam!!
http://www.bloxracing.com/product_in...products_id=81
Old Oct 6, 2010 | 06:17 PM
vmrevo9's Avatar
Veteran: Air Force
i received the Turbo today!!!!!
waiting on the manifold which shows a delivery date of the 8 of october so hopefully this weekend everything can be installed, boost leak tested and ready to go!
Old Oct 6, 2010 | 08:03 PM
EVO8STI's Avatar
what turbo is this?
