Help, Hallman MBC issues
Old Sep 13, 2010 | 09:43 PM
Yakshii's Avatar
so i recently purchased a Hallman MBC as im in the process of getting tuned. So i installed it. It was pretty straight forward.
Went from the wastegate to one part of the MBC.
then went from the turbo elbow to the other part of the MBC.
I capped off the intake nipple
Capped off the 2 nipples off the stock Boost Solenoid and left the harness in.
I Used all new lines. I spun the boost controller all the way to the left so ican be at stock boost levels.
i went for a run and i topped out at 10-11 pounds in 3rd gear. i did a search and realized i forgot the restrictor pill. from my understanding it went on the wastegate side (output). i inserted the pill and same thing. i inserted the pill on the boost source side (input) and now im at 13 pounds. stock is 1.2 bar (17 pounds) on an Evo 7
what did i do wrong?????
thanks
Old Sep 13, 2010 | 10:04 PM
sparky's Avatar
The first thing that you need to do is remove the restrictor orifice. With an MBC you don't want a restrictor pill.
Yakshii's Avatar
Originally Posted by sparky
The first thing that you need to do is remove the restrictor orifice. With an MBC you don't want a restrictor.
hm. when its off, it seems to run like *** though. only 10 pounds
Old Sep 13, 2010 | 10:07 PM
sparky's Avatar
Otherwise it sounds as though you are properly setup. Rotate the MBC's knob three turns in clockwise.
Old Sep 13, 2010 | 10:10 PM
KX250Fmotoracer's Avatar
just curious, is this a real 7?
sparky's Avatar
You need to increase wastegate spring pressure. If you want, I'll run you through the proceedure so that it no longer runs like butt.
Old Sep 14, 2010 | 02:19 AM
adam_79_2005's Avatar
yeah if i remember correctly i had issues with my hallman mbc until my srt4 buddy made me relize the kit came with an additional HIGH spring piece for higher boost aptications, not sure how it all worked but when we swapped springs the problem i had that you have was fixed.
Old Sep 14, 2010 | 04:28 AM
Fast_Freddie's Avatar
Veteran: Navy
Well if you are running wastegate pressure 10-11 psi sounds normal... the boostpill in the stock line and the boost solenoid was what was enabling you to run 17 psi before. You have taken all this out, so crank up the boost controller a click at a time so you are where you were before... make sure there are no boost pills in the lines!
Old Sep 14, 2010 | 05:31 AM
Yakshii's Avatar
yes.
and thanks everyone. i will try
Old Sep 14, 2010 | 09:04 AM
wreckleford's Avatar
Yes, this is correct.
drb
53
Oct 25, 2016 07:50 AM
racer135
Apr 8, 2008 02:29 PM
MitsuJoe
Nov 19, 2006 04:21 PM
AutoEuphoria
Jun 21, 2006 09:24 PM
nyrican
Aug 7, 2005 04:15 PM
