The weirdest build yet?
Old Sep 15, 2010 | 05:23 PM
JohnBradley's Avatar
We were contacted late last fall by a Rally team looking to build an Open Light Class Rally car. For those of you not familiar with rally, its a naturally aspirated AWD class that basically only has 2 rules, adjust displacement legal to FIA rules and no forced induction.
Our tech Jake, has been the rally program testbed for the last year or so. We started with a high compression 2.4 with stock IX turbo in his VIII and made 476/495 at 27psi. On the restrictor we made 314/433 at 24.8psi that I will admit
The pictures to follow are shocking and not normal. Women, small children, those pregnant or wishing to become pregnant, or those generally intolerant should shy away.
The horror of the All Motor Evo-
We havent dyno'd this combo yet (we are going to) but basically this is just the testbed before we commit to a real engine program (HIGH compression, bigger cams, intake manifold, header). The motor hasnt changed too much since Jake's 10:1 2.4 other than we built a quicky header to make it work. It is still SD running on DSM 450cc injectors, 4 bar, and E85, S2s, etc.
Enjoy
Aaron
Old Sep 15, 2010 | 05:30 PM
WRC-LVR's Avatar
im guessing 220-240 whp N/A
Still.... hafta agree that is weird, but maybe not as weird as a Porsche 911 SC jacked way up in the air, playing being a rally car
Teal2nnr's Avatar
huh.......well then lol.....curious to see the numbers
Old Sep 15, 2010 | 05:34 PM
Sharkbite2000's Avatar
With a set of good cams at least 245-252 whp for sure
Old Sep 15, 2010 | 05:37 PM
The final dream would be pretty intense for an all motor, just really have to see how this one does and then some math
[I.R.A.]_FBi's Avatar
y a 4 bar though
Old Sep 15, 2010 | 05:41 PM
This car is not destined to be an all motor car. Jake is going to put his Red back on and drive the car the way it was meant to be. Testing is about keeping the test as inexpensive as possible and maximise the results. So far it has recycled all existing parts that were already on the car or laying around the shop to get a feel for what it would do. Since it normally runs off a 4 bar, why spend a ton of time changing things right?
Old Sep 15, 2010 | 05:44 PM
ok, was just trying to understand why
Old Sep 15, 2010 | 06:00 PM
KX250Fmotoracer's Avatar
Wow lol.
What cams are you going to use? Custom grind, or maybe some N/A DSM's?
Old Sep 15, 2010 | 06:44 PM
Custom grinds to match compression and header if it ends up working well enough that our customer maintains interest. This has GSC S2s in it still since thats what the car normally runs.
Old Sep 15, 2010 | 06:48 PM
FathouseFab's Avatar
Aahhhhhhhhhhhhhhhhhhhh!!!!!!!!!
Old Sep 15, 2010 | 08:04 PM
scheides's Avatar
EvoM Moderator
OMFG GAHHHH!!!!! I hate this rally class. Such epic cars, such abysmal power setups. I love it though, please share the results.
Old Sep 15, 2010 | 09:00 PM
StreetThisEvo's Avatar
I don't think it will break 200 whp N/A. I'll be curious to see the results.
Old Sep 15, 2010 | 10:24 PM
4g63Moon's Avatar
No boost? Interesting though.
Old Sep 15, 2010 | 10:34 PM
AdamRA's Avatar
I don't see it being higher than 180 whp. Very curious though.
BTW- That air filter is fing massive
