car will not shift
Old Sep 18, 2010 | 01:46 PM
vaflyboi757's Avatar
car will not shift
im hoping u guys can help me, i was driving from a friend's home and all of a sudden my car started having problems getting into gear. then shortly after, the car wont go into gear at all. I recently changed the clutch 2 a Exedy twin disk and am still breaking it in, there's just about 350miles on it. does anyone have any ideas?
Old Sep 18, 2010 | 01:52 PM
SLO-EVO's Avatar
check your shifter linkage.
Old Sep 18, 2010 | 02:01 PM
just checked them, there fine, and i noticed that i can only shift gears if the car is off. its there a problem with the clutch, its brand new!
Old Sep 18, 2010 | 04:25 PM
MRolla's Avatar
did you replace the tob? make sure everything was bled if the line was disconted. shift fork install correctly
Old Sep 18, 2010 | 04:37 PM
4RETECH's Avatar
It is clutch disengagement.
Have someone hit the pedal and through the inspection cover see if the discs move.
Old Sep 19, 2010 | 01:57 AM
its fixed now, im a dumbass. just needed to adjust the clutch pedal. thanks u guys
Old Sep 19, 2010 | 02:40 AM
Dynhamik's Avatar
Cool. Glad it wasn't major.
Old Sep 19, 2010 | 03:49 AM
shiiiiiit, ur not the only 1
Old Sep 19, 2010 | 10:30 AM
OK, now this car is really starting 2 **** me off. just got done driving around 2 put some miles on the clutch and now when i put the clutch in the car shakes and the engine sounds like it wants 2 stall. the TOB is new, everything is new. i dont understand whats going on now.
Old Sep 19, 2010 | 08:10 PM
DSMMR21's Avatar
how is your car modded? does the oil light flicker at all? to me it doesnt sound like its the clutch anymore. mine bogs down coming to a stop, does it shake no matter what tho? or after driving?
Old Sep 19, 2010 | 09:24 PM
It only shakes and chatters when the clutch is down, and it sounds fine when its not. i just have a few bolt on. cams, intake, full exhaust, fmic, walbro, dump. etc. anybody have any ideas?
Old Sep 19, 2010 | 10:13 PM
white8's Avatar
Did you get a lightened flywheel? sometimes thats the cause of this...
Old Sep 19, 2010 | 10:23 PM
fugiwara's Avatar
did you install the clutch? if not, talk to the person who installed it, it might has something to do with the workmanship
Old Sep 19, 2010 | 11:22 PM
i installed it, its a exedy twin disk and it comes with a lighten flywheel, everything was torqued. i started it this morning now theres a CEL. im at work now so i can't see what it is. can a bad clutch pedal switch do that? i was just looking at the CEL list and thats the only thing that could be related, but of course i dont kno if thats the problem or not. i kno the chatter is normal with these clutches but the shaking, stalling sound and the hard starting is what i cant figure out.
Old Sep 20, 2010 | 05:17 AM
Had my wife start it and look at the boost gauge, she said the vacuum goes from -16 to -13. vacuum hose issue? and would it run that rough only when the clutch is in, if this was the problem.
