car will not shift
Old Sep 20, 2010 | 05:23 AM
oreoevo's Avatar
Glad it was simple ...mine had the same problem when I shattered my diff into pieces.lol
Old Sep 20, 2010 | 06:14 AM
vaflyboi757's Avatar
so can a vacuum issue make the engine shake like that?
Old Sep 20, 2010 | 10:32 AM
ok so i found out 2 things, the CEL what a P0401, egr vacuum leak, 2 of the 3 nipples on the egr solenoid were broken off. but i thought it would stall all the time not just when the clutch is in. and the rear motor mount bolts werent tight so thats why the car would shake when it was ready 2 stall. i have another question. would it cause the car not 2 start? cause now its terribly hard 2 start it. or is there another problem now?
Old Sep 20, 2010 | 11:31 AM
javicracer's Avatar
chatter is normal on a twin plate, sometimes when you install a new clutch you will have to adjust your bis screw, try to log your car and post the log, u might just need a tune.
Old Sep 20, 2010 | 11:39 AM
do u mean the clutch pedal screw? i never heard of the bis screw, what is that?
Old Sep 20, 2010 | 11:52 AM
an idle screw? ok i'll **** with it, thanks.
mnm27mnm
Driving Techniques
156
Apr 2, 2014 09:36 PM
chrisff521
24
May 5, 2012 12:27 PM
vboy425
10
May 30, 2011 10:32 PM
joedr
Dec 30, 2006 03:21 AM
ScLncerboy
Driving Techniques
44
Nov 1, 2004 05:09 AM
