Reverse Gear issue HELP
Old May 31, 2006 | 10:36 PM
vboy425's Avatar
i have an 04 evo. I can go forward just fine through all the gear. I can't go reverse. Try every test, i can let go of the clutch all the way and car still wouldn't move and the engine still running. WEIRD. When i put it reverse it doesn't feel like it's lock in gear. HELP please
Old Jun 1, 2006 | 01:46 PM
MalibuJack's Avatar
Check your cable, sounds like its adjustment is fouled up and not fully engaging all the way to reverse.. Had you altered anything with the shifter recently? (Bushings, adjustments, etc?)
Have the console apart recently for any reason? Anything get hung up in there? (New wires or whatnot)
Old Jun 1, 2006 | 10:46 PM
vboy425's Avatar
nope, busgins and cable are fine i even adjust my pedal way high too.
Old May 30, 2007 | 09:40 AM
Neuspeed06's Avatar
Did you ever get a fix for this problem? My reverse is completely locked out also, and i just had a ACT clutch installed a week before.
Old May 30, 2007 | 02:52 PM
vboy425's Avatar
wow old thread. yeah i got a Shep Tranny problem fixed.
Old May 30, 2007 | 02:59 PM
Neuspeed06's Avatar
So what exactly was the problem though? Was it the tranny, synchros, clutch, cable? Im stuck with this brand new clutch and no reverse!
Old May 30, 2007 | 06:43 PM
cssaddictm4's Avatar
Adjust the clutch rod and get a new clutch. It will save you a lot of headache in the future...
Old May 31, 2007 | 09:59 AM
Neuspeed06's Avatar
I have a new clutch, it had only 400 miles on it when reverse locked out.
Old May 31, 2007 | 01:55 PM
Murf's Avatar
his tranny goes into reverse but as soon as you try to move it ginds and pops out of gear....
Old May 31, 2007 | 04:33 PM
Neuspeed06's Avatar
^^ That is exactly what mine does. Its at a shop right now, and they cant figure out what is causing it unless they drop the tranny again.
Old May 30, 2011 | 10:32 PM
Spoolinsteve's Avatar
Old thread but any others have similar problems and a possible cause/fix?
jakgal04
Jan 12, 2017 07:35 AM
MuslimEvoFreak
30
Dec 2, 2010 08:53 AM
Evo3573
17
Nov 14, 2010 09:47 PM
pensport
Sep 7, 2009 09:53 AM
Oki Panoki
Driving Techniques
Dec 30, 2007 12:03 PM
