fuel cut and service light
Old Oct 18, 2003 | 08:35 AM
evol53's Avatar
hey hit fuel cut today oops. anyway just wondering if hitting it could trigger a service engine light. Because thats on now! sucks but i have to get an aftermarket blowoff valve so boosting will be more consistant and hold boost at what i want it too, so i wont have to keep fiddling with this mbc. Sometimes it boost 18 sometimes its 21.
Old Oct 18, 2003 | 08:48 AM
evoinit's Avatar
this happened to me twice both when i was in fourth gear
like i was on it then all of a sudden it like hecupped (studdered)
everything is fine now i just thinjk that the boost was a little to high
Old Oct 18, 2003 | 12:48 PM
WILDMAN's Avatar
Yes, it will trip your SES light. Get a fuel-cut defenser. I have an HKS one, and mine is good as new. (22-23lbs boost)
Old Oct 18, 2003 | 04:19 PM
Bluesmaster's Avatar
Re: fuel cut and service light
I hit fuel cut and triggered the ses as well. If it doesn't go away disconnect the battery for 10-15 minutes, then it will. The cool weather has caused many Evos to hit fuel cut. I used larger injectors, an adjustable fuel pressure regulator, and e-manage too get rid of it. Now I can boost 21-23 psi no problem.
Old Oct 18, 2003 | 05:43 PM
WILDMAN's Avatar
By the way, the FCD cost $53. Quick, fast, inexpesive fix.
Old Oct 18, 2003 | 08:29 PM
Speedlimit's Avatar
Admin Emeritus
The fuel cut defender is not without risk. The very nature of the design reduces the margin to safety and the FCD'ers have claimed a few DSM's over the years.
I would be very careful and make sure you clearly understand what the gizmo is doing.
Have fun!
Speedlimit...
Old Oct 18, 2003 | 08:32 PM
MalibuJack's Avatar
Hmm.. I have hit fuel cut several times and it hasn't triggered the SES (CEL).. Maybe I have something else wrong.. I can attest to the leaky nature of the stock BOV though.. Mine made a nice farting noise earlier today under boost.. I think my car is screwed up.. hehe..
Old Oct 18, 2003 | 09:47 PM
neonhero's Avatar
Where did you find it for $53? Also, did you use a Standard, Type H, or Type K3 ? I saw that there was 3 different types on HKS's website.
Old Oct 19, 2003 | 11:30 AM
QuantumEVO's Avatar
FCD is NOT recommended.
Mark
www.Quantum-Racing.com
Old Oct 19, 2003 | 12:14 PM
DynoFlash's Avatar
The FCD on a EVO is a total disaster !
The fuel cut is based upon MAF signal input
Clamping the maf signal then does not give you any more fuel after the cut
I have three much safer options for you
1 - www.dynoflash.com - my product - safely rasies the fuel cut threshold with my stage rev flash - $225
2 - use an emanage - you can get it from Quantum - you can set the clamp point and add in extra fuel with the injector harness based upon map pressure - it works wonders on my car
3 - get larger injectors or a adj fuel pressure regulator and reduce the maf with a safc or emanage
Old Oct 19, 2003 | 12:20 PM
90GSX-03EVO's Avatar
Mark
I agree totally. It's like putting one of those electric turbos from ebay on your car.
Very bad idea.
Old May 31, 2011 | 01:45 AM
Supramane69's Avatar
My car fuel cuts all the time when i get into it and i dont know why or how to fix it....when i get on it mostly at a higher gear its like the motor is about to drop out from uder my car....wat should i do?
Ians06
Sep 20, 2016 03:39 PM
butte
Nov 12, 2015 04:23 PM
My03evo
12
Sep 26, 2011 12:26 PM
gerard
15
Oct 20, 2008 01:00 PM
MattevoVIII
25
Feb 18, 2007 05:25 PM
