wastegate actuator signal line hose diameter
I need to run a 10 ft hose to the rear of my car to control an exhaust cutout controlled by a wastegate actuator. I'm not sure whether to use a hose with a smallish inner diameter (1/8") or a larger diameter (1/4"). Which would promote quicker response?
Thanks!
Thanks!
I would run the 1/4in line. Just make sure you have a solid vac/boost source
Metal and smaller diameter.
A rubber line that long will have a lot of compliance, which isn't good for response. Probably wouldn't matter though as the 0.2 second difference likely isn't going to matter.
[WTB] Wastegate Actuator
ExtremeDSM
Apr 30, 2014 04:54 PM
michiganevox
Jul 6, 2011 07:50 AM
joeymia
88
Dec 20, 2009 06:30 AM
