Overheating
Old Sep 28, 2010 | 09:11 PM
MR White's Avatar
Overheating
I tried searching but did not find anything specific to the issue I had over the weekend. I attended a local autocross club's member's only event. Since it was members only we were able to make quite a few back to back runs (I averaged 47 seconds a run). Anyways, I changed my coolant approximately 2,000 miles ago or around 6 months ado. When I did the coolant change I refilled with 30% coolant and 70% distilled water with a bottle of redline water wetter to boot. Well after about 5-6 consecutive runs I went and parked my car. Before shutting down it idled for maybe 30-45 seconds. I pop my hood to let the car cool and I notice two things: 1) there is a sheen around my power steering fluid reservoir and it looks like some bubbled out the top of the cap.
2) I can hear a bubbling kind of noise coming from the radiator/manifold area.
I go back to the car and turn the key and the water temp gauge pegs to hot. My OEM oil temp gauge read in the middle. I freaked out and turned the car on with heater at full blast and the water temp eventually fell to the middle. I turned the car off and let it cool down. I drove home about 40 mins and did not notice the water temp gauge rise at all. Was this a fluke? The back to back runs overheated my coolant system? Thoughts?
Thanks
Old Sep 28, 2010 | 09:21 PM
Q8_EVO's Avatar
Stock or Aftermarket rad?
something similar happened to me, i was on track for a 20 mins session parked the car after that, then came back in 15 mins to find my car pissed a good amount of coolant
i let it sit for 40 mins, drove it back home (2hr) logged everything... all parameters WNL
ecktt's Avatar
That's normal. Same happened to me first time I went to an event like that. Just let the car idle for a few minutes before shutting off. I eventually got a mishimoto radiator and air diversion plate.
Old Sep 28, 2010 | 09:56 PM
MR White's Avatar
Stock radiator. I just checked my reservoir and found brown sludge most people who use redline water wetter report.
Old Sep 29, 2010 | 07:09 AM
MR White's Avatar
So nothing to be worried about for now? Just make site let the car idle a bit before shutting down next time? I have a turbo timer but I usually just leave it set at 30 secs
Old Sep 29, 2010 | 08:38 AM
andrewzaragoza's Avatar
probably it would be a good idea to drive around before parking like a cool down lap.
Old Sep 29, 2010 | 08:48 AM
evolution2186's Avatar
I would change your fluid and this time leave out the Coolant Additive.
Old Oct 8, 2010 | 05:36 PM
AlwaysinBoost's Avatar
hate to say it but sounds to me like you have a blown headgasket.
Old Oct 8, 2010 | 05:42 PM
MR White's Avatar
I think the brown sludge was due to water wetter. Haven't had a chance to run the at hard again similar to autos circumstances but I have done driving around in the heat and it's been ok so far.
