Forward Facing Turbo vs RAIN
Old Sep 29, 2010 | 11:06 AM
Nomad4g63's Avatar
I want to ask those who are running this setup, and those that sell the kits how do you guys deal with the rain?
And if anyone is running a Forward Facing turbo kit and using there car for DD are there any precautions you are taking to make sure nothing gets in the turbo?
Old Sep 29, 2010 | 11:11 AM
FathouseFab's Avatar
I run a fwd facing kit that allows me to run a filter on it. I don't worry about anything on the street.
Fathouse
Old Sep 29, 2010 | 12:23 PM
BluEVOIX's Avatar
Forward facing turbo + rain = free water injection kit.
But seriously although if you run a filter, it will still get soaked and ingest water that will hit the spinning turbine blades.
I can only think of one thing that will help and that is if they still have the AC heat exchanger. That thing should probably block off most if not all of the rain water.
Old Sep 29, 2010 | 12:34 PM
binh's Avatar
AC heat exchanger won't fit with 95 percent of FF kits out there.
Buschur has a custom block off plate and I will be going with their kit since it allows a filter to be fitted.
Old Sep 29, 2010 | 11:04 PM
MasterNater's Avatar
I run Buschur's FF Kit.
Filter + Carbon Fiber Blockoff Plate = Streetable FF Kit
Old Sep 30, 2010 | 08:07 AM
Nomad4g63's Avatar
the other issue is
theres yet to be a FF turbo kit that keeps A/C
Old Sep 30, 2010 | 08:10 AM
binh's Avatar
Originally Posted by Nomad4g63
the other issue is
Need half size condensor.
Old Sep 30, 2010 | 08:15 AM
aka.ralliart15's Avatar
the other issue is
there is, Diego@TD's Red Evo had one, not sure if you ever meet him though, it was made by Tony@FabWorx
Old Oct 4, 2010 | 01:23 PM
EvoChrisLee's Avatar
Ne 1 running FF with a MAF Translator
Old Oct 4, 2010 | 01:25 PM
kreionic's Avatar
No need to run a translator
Old Oct 4, 2010 | 03:02 PM
I should have said ne 1 with stock ecu running it with a maf translator
Old Oct 4, 2010 | 03:03 PM
kreionic's Avatar
I figured as much but with speed density on the stock ecu theres no need for the translator anymore
tsidrift1
Oct 12, 2016 08:34 AM
twasz
23
Jun 17, 2013 08:03 AM
mullen
Apr 9, 2013 05:01 PM
evo7_8u
Apr 22, 2012 06:00 AM
MrEvo9Mel
Nov 15, 2011 05:18 PM
