Heres what I've found with Tranny Oil
Old Aug 26, 2008 | 03:26 PM
  #61
mrfred's Avatar
Originally Posted by migs647
This is indeed the case. Mitsubishi designs their transmissions AROUND the gear oil. The material the synchros are made of... brass in this case is corrosive with the additives that are put into GL5. You can find this happening all over evom. From regular lancers, to ralliarts, to evos. So many people have toasted trannys because of running Mobil 1's GL5. Stick with GL4 and you'll be in much better shape for longevity.
A GL5-only gear oil is not suitable, but many of the newer gear oils now conform to a newer mil spec qualification that requires better compatibility with copper containing components than the GL4 spec while having better wear resistance than a GL5 gear oil. The specification is MIL-PRF-2105E (aka J2360 after Jan 1, 2004). A good example would be the Amsoil Severe Service gear oil. Its listed at GL5, but it also conforms to MIL-PRF-2105E (aka J2360), so it has excellent compatibility with brass gearbox parts. Not sure how a syncro box would work with an oil like this though.
Old Aug 26, 2008 | 03:28 PM
  #62
DRFTKNGG's Avatar
Add a little Lucus Oil Stabilizer to the mix and it gets even better!
Old Aug 26, 2008 | 05:46 PM
  #63
Evolessfornow's Avatar
I hope that was sarcasm. Link
Old Aug 26, 2008 | 07:02 PM
  #64
Lonnie@LMS's Avatar
We use Redline lightweight shockproof in the trans due to Shep's recommendations from his testing. We use Diaqueen in the t-case and rear diff. We used to use BG synchroshift II and had no issues with it to think of but changed cause Shep builds our customers tranny's.
Old Aug 26, 2008 | 07:44 PM
  #65
C6C6CH3vo's Avatar
BG might work in well in Alaska, too thin here and made too much heat, for me in my climate MT90 for about 60,000 miles (changed about 6 times) seems to do the trick
Old Aug 26, 2008 | 09:51 PM
  #66
mojo's Avatar
I just changed from MT-90 to Amsoil MTG. I also put Amsoil SVG in the transfer case and rear diff.
Shift is nice and smooth. I wasn't unhappy with the MT-90 but I like this better.
Oil Doc is great! Thanks Oil Doc
http://bestoil4you.com/Evo.html
Old Aug 27, 2008 | 12:33 PM
  #67
Kracka's Avatar
Redline MTL/MT-90 mix for all my cars and I love it!
Old Aug 28, 2008 | 07:02 AM
  #68
Davo's Avatar
2mt and 1 mtl or 2mtl and 1 mt?
Old Aug 28, 2008 | 07:17 AM
  #69
nightwalker's Avatar
I have 120k miles and have always used Mitsu Diaqueen. Switched to BG II for 10k miles, and my transmission was pregressively getting notchier. Went back to Diaqueen and it fixed it. Never used anything else since then.
If you race, just change it out more frequently.
fightex
Jul 6, 2012 05:58 AM
gvr4615
West Region
Jan 21, 2010 11:11 PM
czilla
Mar 28, 2009 10:58 AM
dsycks
Mar 23, 2007 06:42 PM
Danny23
32
Aug 28, 2006 05:19 PM
