Timing belt alignment with oil pump/balancer screwdriver trick. Where should I orient
Old Oct 3, 2010 | 06:27 PM
hoof hearted's Avatar
the oil pump timing belt gear???
I have the bolt out and the screwdriver can be inserted a few inches per manual but it is not a locking stop.... I can still spin the oil pump sprocket about 35 degrees... Do I center it in the middle of the swing???
THANKS!
Old Oct 3, 2010 | 06:42 PM
EVO8emUp's Avatar
I have the boly out and the screwdriver can be inserted a few inches per manual but it is not a locking stop.... I can still spin the oil pump sprocket about 35 degrees... Do I center it in the middle of the swing???
THANKS!
Align it with the arrow. The screw driver only lets you know that's it's not 360* out. the full cycle is 720*
Old Oct 3, 2010 | 07:03 PM
I am not able to align the white paint dot on the face of the oil pump gear with the arrow @ 11:00 without removing the screwdriver. (It will go to about 9:00 screwdriver in...)
Do I need to spin it more revolutions? (It is very close to where it was when I removed it).
I am repairing a 60k mi. service job where my local shop didn't tighten the crankshaft bolt.... Took out my crank sensor, plate and crank key was messed up a bit. Everything else is ok.
Lesson learned... If you have no time to do it yourself... FIND TIME.... or you'll be finding time to re-do it... lol.
Thanks!
Old Oct 4, 2010 | 09:06 AM
Hoping someone can help!!!!
Old May 20, 2011 | 02:31 AM
GRNCT9A's Avatar
did you figure it out?
Old May 20, 2011 | 09:00 AM
barneyb's Avatar
What is it you need to know?
anthonypazsd
135
Apr 2, 2026 12:56 PM
Ferp
Jul 20, 2017 02:48 PM
bpdean
19
Dec 29, 2015 03:08 PM
delta6force94
Oct 31, 2015 08:24 AM
KevOVIII
18
Nov 10, 2005 08:05 AM
