evo drivetrain transplant
Old Oct 4, 2010 | 07:17 AM
jordan_turbo's Avatar
alright guys, just signed up on here for a bit of advice.
i own a vauxhall astra turbo currently running FWD and about 300bhp, im looking at converting it to 4wd to help get the power down and because the engine is transverse im looking at using evo running gear to do it.
im happy with the fabrication work of fitting it all and mating it up to my current engine, the question i want to ask is will the evo gearbox, and diffs etc... work without all the electrical gubbins like active yaw control connected? does it have a set torque split that it will revert too?
thanks in advance
Old Oct 4, 2010 | 07:26 AM
gsrboi80's Avatar
I have an Astra too USDM Saturn model. Slow but good on gas.
If you were to use a drivetrain out of an 03-04 USDM EVO then you would not have all the electronic bits you mentioned.
No AYC
No ACD
Old Oct 4, 2010 | 08:01 AM
sounds good but im in england
Old Oct 4, 2010 | 08:18 AM
gsrboi80's Avatar
Yea unfortunately all over the pond cars were equipped with the electronic bits. Maybe look for anyone who has imported a USDM car to Europe or see if you can import a drivetrain over. Maybe a little pricey but the project you want to undertake is not a cheap one anyway. GL man
Old Oct 4, 2010 | 09:19 AM
kikiturbo's Avatar
that is not a problem... what you need is the gearbox and transfer box from an old EVO, like Evo 4,5,6, those did not have ACD...
Rear diff, you need a RS diff, which has a plate dif, without AYC....
If I were you, I'd save myself a lot of hassle, and buy an EVO engine also.. sell your vauxhall engine.. 4G63 is a veryy good basis for mega power...
Old Oct 5, 2010 | 07:41 AM
cheers for that info, thats helped me out loads
i could buy an EVO engine but then again you could say i should save all the hassle and buy a whole EVO and wheres the fun in that
the vauxhall C20LET is still a good basis for plenty of power and means the car will still be mostly vauxhall if vauxhall had ever made a good 4WD system id use that too but they didnt so im having to branch out
UmbraEVOlveD
Jan 22, 2014 02:39 PM
superkizuna
Dec 14, 2013 05:57 PM
harlintuliau1
Dec 3, 2013 04:05 PM
MadBoostedEvo
Nov 11, 2012 10:25 AM
worksevo89
12
Aug 14, 2009 07:15 PM
