Does the front balance shaft have a keyway to orient the timing belt sprocket?
Old Oct 4, 2010 | 06:31 PM
hoof hearted's Avatar
I'm trying to put my timing belt back on but my oil pump/ front balanceshaft paint mark doesn't line up with the mark with the screwdriver in the hole...
First pic is what I have with screwdriver in hole... (white paint about 8:00)
I have turned the balanceshaft as far as I can until it hits the screwdriver.
Last pic is where I assume it should be (On the tab) but the screwdriver cannot be inserted.
Could the sprocket be improperly installed on the balanceshaft? (Is it a spline or a keyway)
Thanks!
Attached Thumbnails Does the front balance shaft have a keyway to orient the timing belt sprocket?-dsc_3378.jpg   Does the front balance shaft have a keyway to orient the timing belt sprocket?-dsc_3379.jpg
Old Oct 4, 2010 | 07:45 PM
CharlieGsanD's Avatar
the pulley is keyed to the shaft
the pulley & the balance shaft are on a 4-1 ratio, try turning the gear four complete revolutions, checking each time & see if it will go in any further, when you have it correct the gear will self center at the 12:00 position and the screwdriver should go in up to the handle (assuming there isn't friction keeping the gear from rotating, which isn't uncommon)
Old Oct 5, 2010 | 02:20 PM
I followed your advice and it lined up properly after one revolution!!!!
THANKS !!!
Old Oct 5, 2010 | 06:34 PM
no worries, glad you got it sorted out
Old Oct 18, 2010 | 07:33 PM
I got the car back together, up and running.... Thanks for the help!
anthonypazsd
135
Apr 2, 2026 12:56 PM
hoof hearted
May 20, 2011 09:00 AM
hoof hearted
Midwest Region
Oct 29, 2010 11:03 PM
hoof hearted
Oct 18, 2010 07:35 PM
KevOVIII
18
Nov 10, 2005 08:05 AM
