dumb oil pressure question
Old Oct 8, 2010 | 01:24 PM
m34g63's Avatar
03 evo VIII, 80k, i use mobil1 10w-30, stock internals and my oil pressure gauge is installed on the oil filter housing. when i start my car the oil pressure is 30-35, but when warmed up it drop to around 20 is this normal? if so how low is too low?
Old Oct 8, 2010 | 02:24 PM
tundeclips's Avatar
... hmm
it will drop for sure mostly (i think) because of the oil is now thinner due to heat needing less pressure to force around. My PSI guage usually reads 35~ on startup but dips WAYYYY down to around 5 when idling hot... i don't know which one of ours is normal but mine seems to run like a dandy. ::shrugs::
Old Oct 8, 2010 | 06:09 PM
Berts24's Avatar
that's strange because at start up mine reads like 75 and once warmed up it's about 12.....I have an 8 too with stock internals
Old Oct 8, 2010 | 06:57 PM
cij911's Avatar
You are fine...
Old Oct 8, 2010 | 07:22 PM
signature sound's Avatar
https://www.evolutionm.net/forums/se...ating-prv.html
Old Oct 8, 2010 | 07:31 PM
how low is too low depends on how you drive the car. ideally the set clearances for the bearings are designed for the type of oil recommended. as long as oil stays between the metals, you will be fine. if you are pushing it harder than what the oil pressure can keep up with, then you are not fine. it is very normal for he oil pressure to drop during warm up due to the viscosity changes. but keep in mind you dont want it to squeeze out at any point weather idling or anything.
you may want to consider a higher viscosity oil as your mileage gets higher. just dont go too much different becasue while pressure keeps a cushion between the metals, the flow is important for cooling.
Old Oct 8, 2010 | 07:52 PM
cssaddictm4's Avatar
Originally Posted by cij911
You are fine...
+1
I read about 100 on start, 40-60 cruise, and 15-20 idle. Evo's are famous for having low oil pressure at idle.
Old Oct 8, 2010 | 08:07 PM
Originally Posted by cssaddictm4
+1
thats how mine is, but by choice
Old Oct 8, 2010 | 11:52 PM
tscompusa2's Avatar
Originally Posted by tundeclips
... hmm
5psi is not ok
Old Oct 9, 2010 | 08:34 AM
m34g63's Avatar
ok good i feel better, thanks guys!
Old Oct 9, 2010 | 05:09 PM
barneyb's Avatar
Originally Posted by tscompusa
5psi is not ok
Yeah, I think according to Mitsubishi not less than 4 is okay. I'd have to check the service manual again to be sure but that is what I remember.
Old Oct 9, 2010 | 05:33 PM
tscompusa2's Avatar
ok well i spun a rod bearing with 15psi, but i have no balance shafts. i normally idle around 30-40. if you ever question your oil pressure at anytime be safe and check your dipstick asap!
Old Oct 9, 2010 | 08:21 PM
Berts24's Avatar
yea I remember reading that the light will come on at 4 psi, I wouldnt be comfortable with 5
Old Oct 9, 2010 | 10:02 PM
when you do an oil change, is it better? then gradually gets bad to 5psi after a short time? Did you smell your dipstick? Any gas in the oil? You could have leaky injector(s). Dunno.. just throwing **** out there
Old Apr 11, 2011 | 02:30 PM
melllow's Avatar
mine is anywhere from 6-15 PSI when the car is fully warmed up is this a problem?
