Megan o2 Housing
Old Oct 8, 2010 | 07:46 PM
erald01's Avatar
Megan o2 Housing
I just got a brand new megan o2 housing and i noticed there is a gap under the flange from one hole to another is that normal?? here is a cpl of pics for reference, kind of ****ty pics but thats the best i can do for now, the gap is underneth the middle flange where the two ports meet...
Old Oct 8, 2010 | 07:51 PM
binky's Avatar
Looks like poor workmanship...
Usually Megan Racing's O2 housing are pretty good.
However - as long as the welds on the outside are OK and the two ports are separated you should be fine.
Still - you just got it, if I were I would think about contacting Megan Racing and see what they say.
-Bink
Old Oct 8, 2010 | 08:27 PM
TommiM's Avatar
Contact Megan and see what they can do for you. I dont think that is normal. Maybe that area didnt get a good enough weld.
Old Oct 8, 2010 | 08:42 PM
erald01's Avatar
so the ports need to be seperated?? is it bad for performance wise???
Old Oct 8, 2010 | 09:11 PM
erald01's Avatar
the thing is that the outside welds are perfect its juston the inside that there is no welds at all, i bought it from ebay so i hope megan will exchange it or ill have to pay extra and weld it on the inside
Old Oct 8, 2010 | 09:16 PM
binky's Avatar
Yes - it defeats the purpose of having a twin scroll turbo then.
I would try to either get a refund or a replacement.
If you get a refund, do yourself a favor and get the Invidia O2 housing.
-Bink
Old Oct 8, 2010 | 09:19 PM
erald01's Avatar
yeah thats true but i heard invidia requires some modification to the o2 sensor wires..
Old Oct 8, 2010 | 09:25 PM
binky's Avatar
It does, but it's easy. All you have to do is extend the wires. A nice wire crimper, and some wire and some shrink wrap (or electrical tape) and your golden.
Once you see the size difference between the two, you will wonder why you even looked at the Megan.
-Bink
Old Oct 8, 2010 | 09:30 PM
erald01's Avatar
i dont know i think i might just keep it and weld that little gap, btw how strong can jb weld be, will it withstand the hot exhaust, i just dont want to go through returning it for a gap that can be welded easily, the gap is prolly 3mm so its not that bad
Old Oct 8, 2010 | 09:37 PM
binky's Avatar
JB weld is good stuff. Off the top of my head not sure of the heat rating.
Nothing bad will happen if it starts to chip since its post turbo (maybe if you have CAT you will see an issue of it clogging).
Try it - nice easy cheap solution.
-Bink
MJ23FE's Avatar
-Bink
What does an o2 housing have to do with a twin scroll turbo? all it does is route spent gases away. The only time you should be concerned with a twin scroll setup is with the runners and collector, as well as the turbine. Anything after is spent in regards to the scroll.
-Jalal
Old Oct 8, 2010 | 10:04 PM
binky's Avatar
-Jalal
If that were true - then why are they separated in the O2 housing? Yes, I understand what you are saying. However, This has been talked about and covered a bunch of times. Maybe I'm thinking of something different - like the MAP O2 elim and the flapper, I don't know...it's late...headed to bed.
-Bink
Old Oct 8, 2010 | 10:14 PM
MJ23FE's Avatar
-Bink
-Bink
It's one of the few, if not the only o2 housings that has the split. The turbine itself has a single outlet for the exhaust and an outlet for the wastegate. It's not split on the exhaust outlet of the turbine. The gases are spent and released.
-Jalal
Old Oct 9, 2010 | 07:57 AM
erald01's Avatar
so then should i return the o2 housing or keep it?? is it okay if exhaust gases pass from one port to another???
Old Oct 9, 2010 | 08:05 AM
SwishaSweet's Avatar
Megan makes garbage, return it
