Vac Lines.
Old Oct 9, 2010 | 05:53 PM
EvoVIII808's Avatar
Vac Lines.
Stupid question, but where does the nipple on the Front of the RNR35R kit connect to. The wastegate right?
Problem is i have 1 nipple (side) on the wastegate running to the AVCR controller, and the top does not have a nipple to connect to.
Do i need to get a nipple and run it from the top of the wastegate to the front of the turbo?
Old Oct 9, 2010 | 06:41 PM
cssaddictm4's Avatar
A typical install is as follows.
Mbc:
Pressure source from compressor housing to mbc.
Mbc to bottom of the gate.
Top port of gate is unused.
Ebc:
Pressure source from compressor housing to bottom of gate and ebc
Ebc to top of the gate
Blake
Old Oct 9, 2010 | 07:23 PM
EvoVIII808's Avatar
So reading this, it sounds like i need to T into the gate and turbo then over the AVCR.
Old Oct 9, 2010 | 07:24 PM
SLO-EVO's Avatar
Exactly. Which WG are you running?
Old Oct 9, 2010 | 07:33 PM
EvoVIII808's Avatar
Lol i was about to PM you. Man you know i got the Tial 44mm.
So here is the Deal. There is no nipple on top. Bottom is connected Directly to the Boost Sol.
Which leaves the nipple on the Turbo Open.
Pics will be up in 5 min.
Old Oct 9, 2010 | 07:37 PM
SLO-EVO's Avatar
if I remembered EVERYONE'S setup, I would be a genius. the nipple on the turbo is supposed to be for your boost control. post up pics. I am going to switch MWRs so I can see them.
Old Oct 9, 2010 | 07:44 PM
EvoVIII808's Avatar
K they are loading up right now. Was playing with a Z06 last night, and just noticed he walking away.. and was like NO WAY!!. then was i only boosting 10psi (Which is BS!) so finally did a boost leak test and found the nipple on front of turbo was not there and i really didnt remember where it went.
just connected the line and was like, where does it go???
Old Oct 9, 2010 | 07:48 PM
EvoVIII808's Avatar
Top Pic - the line goes directly to the COM side of the AVCR Boost Sol from the wastegate.
Bottom Pic - is the line that need to go somewhere, but where??
Old Oct 9, 2010 | 08:38 PM
SLO-EVO's Avatar
your picture taking skills are horrible lol.
Old Oct 9, 2010 | 08:45 PM
SLO-EVO's Avatar
also trim the end of that rubber hose on your wastegate. its all cracked.
Old Oct 9, 2010 | 09:30 PM
EvoVIII808's Avatar
Lol its not cracked, and that's electrical tape haha. And my picture taking skills are boss.. Any thoughts. If I remember correctly the stock turbo has a nipple off of it and T to the wastegate. Maybe ill try that.. Or ill just block it off
Old Oct 9, 2010 | 10:40 PM
SLO-EVO's Avatar
yeah. my original thought was to block it off. if you call that boss, i am a god lol. im jfwy i love you. i would try both ways. they t off then run to the intake manifold. if you want hit me up on PM with your email. I swear i have a shop manual somewhere.
Old Oct 9, 2010 | 11:20 PM
EvoVIII808's Avatar
Yeah, i remember the stock way. I think its also under the hood somewhere too. or maybe thats just the eclipses. Im gona block it for now and see. also just finished up a new map for meth
hopefully it pulls hard.
Old Oct 9, 2010 | 11:22 PM
EvoVIII808's Avatar
Cant show everyone the whole engine bay. lol that would be giving away all my secrets.
Old Oct 9, 2010 | 11:24 PM
SLO-EVO's Avatar
it is under the hood. when you are looking at it popped it is on the upper right corner. good luck man. wish i was there. seeing as how we live like 5 blocks away from eachother lol.
Flyhigh
Aug 12, 2025 09:51 AM
Raceghost
Mar 11, 2019 01:04 PM
drb
53
Oct 25, 2016 07:50 AM
rz
Sep 2, 2015 02:03 AM
ta ace
Apr 3, 2011 05:59 PM
