Converting T-Case to FWD
First off let me explain that my chassis is built for FWD-only right now. That is the reason I need to convert my Evo transfer case to FWD. I simply don't have the off-time to fabricate the AWD rear...yet.
So with that out of the way, can any of you give me some insight on the process? I've been doing some research and that tells me to remove the rear shaft and weld the spider gears together, much like a welded rear diff. Following that, I fabricate a cover plate and close up the transfer-case.
What I want to know is, have any of you done this? Are there any other options beside installing an AWD rear?
I appreciate any help. I don't want to see any posts saying "FWD sucks, why would you do that?". I just explained my situation and this is my current and most cost/time effective option. Plus I already know, FWD sucks
Thanks
Thanks
Yeah it's going into the Mirage. There is room there to install everything. I may need to take a small amount of metal off the subframe, if anything.
And I would wait, but it I'm still doing a lot of research on fitting the AWD rear. Not the most documented subject out there, unfortunately. That and it's my DD
if you were going FWD, i'd just get a 4g6* fwd gearbox and be done with it...
The only possible gearbox is the one from an Eclipse and that would be too expensive to look into.
I guess what I need to know is, is welding the center diff gears the only option I have with the transfer case? or are them some methods of converting it to FWD that may be reversible?
I apologize for my lack of knowledge on this sort of thing.
The transmission on a 3G Eclipse 2.4L could work but they would have an issue with clearance (starter is where turbo will be) and they are pretty uncommon.
Thanks for the info everyone, looks like I'll have it welded up.
So I finally got around to starting my swap. Right now I am torn between going FWD and going AWD. If I stay FWD I will have access to my car sooner, but will sacrifice tearing apart my transmission and permanently weld the center diff.
However if I go AWD it will further push back my timeline and I don't necessarily have the funds available right now.
So in my thoughts, I would like to know if it is safe to drive without the rear shaft? I know it must be removed and then covered to prevent spilling fluid, but would it operate safely? And I am talking about sub 4k rpm, slow city driving.
Thanks for the help. Any input is appreciated!
You'll burn out the viscous coupler Brent, you don't wanna run that tranny in fwd without work. The ralliart tranny is the best option. It should bolt right up an they're much cheaper than the eclipse gearbox. Check ebay.
I think you need to permanently lock the viscous coupling. Then, you still have the front differential. I'm not sure how you would do this. Maybe someone knows.
