need a math check!
Old Oct 19, 2010 | 06:43 PM
n2oiroc's Avatar
need a math check!
deck height: 9.248"
rod length: 6.142"
stroke: 3.700"
cylinder bore: 3.425"
gasket bore: 3.425"
gasket thickness: .047"
combustion chamber: 48cc
piston dish: 6cc
with .002" piston to deck height i get a compression height of 1.254" and a static compression ratio of 10.19:1 correct? thanks!
Old Oct 19, 2010 | 07:28 PM
Aby@MIL.SPEC's Avatar
at the end of the day, it comes down to:
*where your piston top is relative to the deck / measure in-line with piston pin.
*cc's in cyl head.
*head gasket thickness
*head gasket diameter
*bore diameter
*figure 0.7cc crevice /top land / ring land volume
*piston dish volume
*stroke
in order to get your static cr.
Old Oct 19, 2010 | 07:41 PM
n2oiroc's Avatar
*cc's in cyl head.
*bore diameter
*piston dish volume
*stroke
im mostly looking for a double check in compression height and dish volume as im about to order pistons and dont want a set of paperweights.
