Question about Lifters
Old Oct 26, 2010 | 07:12 PM
PaperClip's Avatar
I found some revised hydraulic no tick lifters. I was wondering if lifters can be changed without removing the cam. I have some lifters that are ticking more then normal at idle. When I installed the cams I bled all the lifters. Thanks for the info.
Old Nov 8, 2010 | 08:57 AM
njvlllrs's Avatar
You must pull the cams...
Old Nov 8, 2010 | 10:16 AM
barneyb's Avatar
Back in the '90's prying out the followers and replacing lifters on DSMs without removing the cams was the most common procedure. I don't know what would be different about the Evo engine.
When it came time to replace the lifters in my DSM engine (lifter problems were near universal) I couldn't bring myself to do it. I pulled the cams.
Old Nov 8, 2010 | 10:24 AM
Fast_Freddie's Avatar
Veteran: Navy
There is an actual tool to do it in car... I have one...
Schley P/N 99700
Bluepoint P/N YA9970
Old Nov 8, 2010 | 11:39 AM
Dallas J's Avatar
Veteran: Army
Ive done it on DSMs dozens of times with the cams in and IIRC its the same process for an evo. You can always check on Vfaq.com for pictures on how DSMers do it.
