Bending turbo compressor fins
Old Oct 26, 2010 | 08:09 PM
foxbat's Avatar
Is it true that some tuners intentionally bend turbo compressor fins, making the turbo spool much sooner than usual ?!
Old Oct 26, 2010 | 08:13 PM
4RETECH's Avatar
Never heard of that. How would they be able to bend all of them equally.
If anything, I think people would upgrade the compressor wheel and housing.
Old Oct 26, 2010 | 08:22 PM
foxbat's Avatar
I know this sounds strange & haven't seen how it's done, but I've seen the result, a friend's E9 GSR is now spooling around 600rpm sooner after the tuner performed this "pending operation" which took like an hour to do!
Old Oct 27, 2010 | 02:28 AM
pettyboy69's Avatar
sounds pretty skechy to me, the aluminum in the compressor wheel is very very brittle and easy to break, i wouldn't do it if it were me
Old Oct 27, 2010 | 10:02 AM
foxbat's Avatar
I'm discussing it with a friend, now, I tend to think that the pending is applied to the turbine blades.
Old Oct 27, 2010 | 10:11 AM
rcheung's Avatar
I knew someone that had that done to the turbos on his 300zx but im not sure what the advantage was.
Old Oct 27, 2010 | 10:12 AM
Locdizzel's Avatar
sounds like a bad idea
Old Oct 27, 2010 | 10:14 AM
rcheung's Avatar
Heres a thread I found on this forum about this.
https://www.evolutionm.net/forums/ev...ing-turbo.html
Old Oct 27, 2010 | 10:24 AM
Genesis8's Avatar
I think it was called clipping or something like that.
Old Oct 28, 2010 | 12:11 AM
pettyboy69's Avatar
if you actually clip anything off you will have to rebalance the whole thing cuz the weight is different
Old Oct 28, 2010 | 06:46 AM
foxbat's Avatar
This might be it, I know for a fact that performance greatly improved after performing this "bending or clipping?" I've seen it done on an Evo & an STi. I'm tempted to do it but my only fear is that the turbo would have a much shorter lifespan.
Old Oct 28, 2010 | 06:58 AM
Jarrett 03's Avatar
this sounds like a bad ideal to me
Old Oct 28, 2010 | 07:05 AM
TxEvo8's Avatar
The turbo spins at like 150k rpm, I would not alter it in any way..
Old Oct 28, 2010 | 07:25 AM
NJ_EveOhVIII's Avatar
Patent pending stuff right here.
Old Oct 28, 2010 | 07:30 AM
05blue8's Avatar
Hiring a tuner for $300 to tune your car and clip your turbo fins without rebalancing them will in fact shorten the lifespan of it, by how much it's probably a guess based on how far off balance the shaft and wheels are. If you hired a professional group such as FP to do it and rebalance the assembly I'd say go for it. Once something gets out of balance it can wobble, make contact with the housings, etc etc. If you look you can see how tight the tolerances are to the housings, that isn't much wiggle room when things wobble.
