50hp gained, 30% fuel saved from K & N filter!!
Old Dec 1, 2003 | 09:30 AM
raywong's Avatar
I think my K & N splashed oil on my MAS, I feel like my car gained 50+hp, and it is doing 30% better on milage. I am a little worried that it is running too lean.
Is there any way to clear the MAS?
Old Dec 1, 2003 | 09:35 AM
MP5's Avatar
MP5
In Timeout
Re: 50hp gained, 30% fuel saved from K & N filter!!
Bawahhaaa If it makes HP its cause its causing the MAF to misread and lean out! So take the MAF off and put it in a big ziplock and spray it with non-clorinated brake cleaner- let it dry and reinstall
Old Dec 1, 2003 | 09:43 AM
majik211's Avatar
You could use the non-chlor brake clean but if the oil made it into the vent holes in the post of the MAS you may have to VERY VERY VERY CAREFULLY directly clean the internal post.
Old Dec 1, 2003 | 10:14 AM
raywong's Avatar
I just took apart the air box, there were red oil droplet all over the place. the honey comb thing looks dry, I couldn't take the internal post apart to check it. any suggestion?
Old Dec 1, 2003 | 10:22 AM
ShapeGSX's Avatar
The post is just a post. There are no electronics in there. The post is specially shaped to create vortices in the airstream. Oil won't hurt it.
Read this:
http://members.rogers.com/mrjackson9/MAF/MAF_Detail.htm
What you guys are thinking of is a hotwire MAF. Evos and DSMs don't have those.
An air filter can give you better power by decreasing vacuum in the tube before the turbo. This can increase turbocharger efficiency slightly. And it can help the turbo spool faster. The faster spool can lead to the perception of greater horsepower, though, since it increases the rate of acceleration increase or "jerk" (1st derivative of acceleration).
Old Dec 1, 2003 | 10:49 AM
raywong's Avatar
a test pipe was installed day before the K&N, I understand now it will gain me some power, but why am I getting so much better mile/dollar??
Old Dec 1, 2003 | 10:56 AM
ShapeGSX's Avatar
I got much better highway gas milage when I installed a test pipe. It is a huge restriction in the exhaust stream.
I used to get 21/26mpg (city/highway). Now I get 19/31mpg.
Note that at steady cruise, the MAF reading isn't relied upon as heavily as it is during WOT. The ECU uses feedback from the O2 sensor to adjust the fuel delivered. So even if the MAF was giving faulty readings, you wouldn't see a huge change in fuel consumption. The change in fuel usage is due to the greater efficiency of the entire system.
Old Dec 1, 2003 | 11:05 AM
raywong's Avatar
thanks!
should I bring the car in to check the a/f ratio, just to be safe?
Old Dec 1, 2003 | 11:15 AM
ShapeGSX's Avatar
That is up to you.
Old Dec 1, 2003 | 12:32 PM
majik211's Avatar
Re: Re: 50hp gained, 30% fuel saved from K & N filter!!
Sorry guys guess I took it the wrong way.
It sounded like he dam near doused the MAS in recharge oil, thats why I said take the post cover off.
Hope you didnt get any on the honeycomb, I wouldnt clean it with any thing to harsh cause it has a NC coating on it, I found that out when I put my order in for a sheet of it.
So, just a heads up.
Old Dec 1, 2003 | 12:41 PM
AutoXer's Avatar
Originally posted by ShapeGSX
...increases the rate of acceleration increase or "jerk" (1st derivative of acceleration).
Shape, I had respect for you before... But now you are THE MAN!!! Anyone who knows that jerk is a quantfiable term and can state the definition, gets much respect from me.
Old Dec 1, 2003 | 01:01 PM
Buster42's Avatar
Shape
That link is fantastic
Thanks
Old Dec 1, 2003 | 01:06 PM
Buster42's Avatar
Shape
Thanks
Old Dec 1, 2003 | 01:15 PM
ShapeGSX's Avatar
Originally posted by Buster42
Shape
What can I say? I'm the man!
Old Dec 1, 2003 | 02:39 PM
Zeus's Avatar
...what can one say to that?
